Rattling Metalic Noise
Old Jun 15, 2017 | 08:34 AM
Del Robinson's Avatar
Default Rattling Metalic Noise
Hi, I have a 2010 XF 3.0TD S with 150K on the clock, Im a little concerned as I can hear a metallic rattling coming from underneath the car (I think its underneath) when Im driving, its not present on idle.
The noise sounds like a marble in a tin can, its more noticeable when accelerating but is present sometimes when going over bumps ect. I can only hear it when the windows are down.
No warning lights, no code errors and just had a service
Any thoughts?
TIA
Old Jun 15, 2017 | 09:20 AM
stmcknig's Avatar
I'd check for loose mounting brackets and heat shields first...
Old Jun 15, 2017 | 09:28 AM
mrathell's Avatar
Ha, I just posted yesterday the resolution I found for that issue:
https://www.jaguarforums.com/forum/x...solved-183909/
I'm posting this just in case anyone else has/will experience it.
My 2009 XF V8 (NA) would have a nasty sound coming from the rear end when accelerating.
It didn't make the noise all the time. Sometimes at 10mph, sometimes at 30 mph, sometime at 70mph but I had to be applying the gas pedal for it to initiate.
I was told it was the universal joint. I was told it was the prop shaft bearing. I was told it was the rear diff.
All plausible but I didn't fully agree because the sound wasn't rotational.
So recently I crawled under the car and noticed all of the heat shields lining the area where the drive shaft ran. Several of the heat shield panels were loose. So I put strips of foam between the loose panels.
The noise is now 100% gone.
I'm glad I didn't listen to the Jag dealer
Old Jun 17, 2017 | 07:41 PM
BritCars's Avatar
I hope it's high temperature foam or you'll smell burning smells from the foam
Old Jun 17, 2017 | 08:02 PM
OzXFR's Avatar
I did the same with my old XFS, but I made sure to push the strips of foam rubber well outboard and away from the exhaust pipes.
Old Jun 17, 2017 | 08:41 PM
mrathell's Avatar
It's not high temp foam. I've put over 400 miles on the car since I did it and it's been 90 degrees Fahrenheit most of those days with no issues or smells yet.
Old Jun 20, 2017 | 10:09 PM
BritCars's Avatar
That's good to know. Thanks!
