Rear brake light
Old Dec 6, 2024 | 08:29 AM
Scarbot's Avatar
Default Rear brake light
Scratchy head time!
When my lights are off the brake lights work fine. When I turn the lights on, the rear brake light on the passenger side is permanently on - any suggestions please, MOT on the horizon.
Thanks!
Old Dec 6, 2024 | 02:53 PM
John Williams's Avatar
Check you have the correct bulbs fitted.
Old Dec 6, 2024 | 08:13 PM
POD XF's Avatar
Odd electrical issues like this are often caused by a bad earth, the tail lights may be earthing through the stop light bulb. Used to be very common on older cars, sadly things are not often so simple these days but I'd start by checking the earth connections to the tail lights.
Old Dec 7, 2024 | 05:58 AM
Scarbot's Avatar
Cheers John, worth a check.
Old Dec 7, 2024 | 05:59 AM
Scarbot's Avatar
I will check it, appreciate the response
jag guy 02
Oct 10, 2021 06:50 AM
fhowell
Jul 1, 2015 05:11 PM
03strblackcat
Dec 14, 2011 09:13 AM
bbqit2
May 21, 2009 12:16 AM
