Rear door lock actuator
Old Apr 8, 2018 | 03:43 PM
BritCars's Avatar
Default Rear door lock actuator
I have an intermittent issue with the rear right hand side door lock actuator on my 2010 XF SC. I know it has been well covered as an issue but this is the first of mine to go. I pulled the codes and I can see B110B rear passenger door central locking motor fault. (Left hand drive so that's the right side)
Anyone know the part number - I can find the part for the left door both with and without passive opening, but can only find it for the right hand door without it
I plan to do it myself - looks a bit fiddly but not too hard. Anyone done it recently? Any guidance?
Old Apr 8, 2018 | 08:20 PM
JBzXJ40's Avatar
Yep, done a few of these.
Window and regulator need to come out.
The exterior door handle also needs to come out as well.
Once out, there is a plastic cage/bracket that is connected to the latch. There is a rivet that you'll need to drill out and replace.
I suggest getting some body shop tape ( Green ) to tape off areas around the exterior door latch to prevent scratches.
NOTE:
Remove the screw sufficiently, only to release the component.
Torque: 4 Nm
NOTE:
Some variation in the illustrations may occur, but the essential information is always correct.
CAUTION:
Take extra care not to damage the wiring harnesses.
NOTE:
Secure the connection in the service position.
Installation
  1. CAUTION:
    Make sure that the wiring harnesses are correctly located.
    To install, reverse the removal procedure.
Torque: 3 Nm
Torque: 7 Nm
CAUTION:
Note of the routing of the wiring harnesses.
NOTE:
Do not disassemble further if the component is removed for access only.
  • Drill out the rivet.
  • Release the clip.
CAUTION:
Old Apr 9, 2018 | 05:54 PM
BritCars's Avatar
Thank you - terrific guidance. There is also a great video on YouTube if anyone else is looking to do this. Literally step by step!
Old Jul 17, 2020 | 10:52 AM
funchris's Avatar
Default Great help, thank you.
I hope my fix goes as well as this and that the extra micro switch on the external handle doesn't cause me any problems!
RaceDiagnostics
Sep 7, 2024 02:26 PM
gregg5788
Jul 10, 2024 02:34 PM
autocad23
Jun 8, 2020 09:18 PM
Yash swamy
Apr 7, 2020 09:22 AM
m0t0rm0uth
Interior
Jan 6, 2010 08:01 AM
