Rear interior light, how to remove bezel
The headliner has pulled out from around the rear interior light in my 2009 XF. Can anyone advise as to how to remove the light cover/bezel so that the headliner can be tucked back in?
Gently lever the plastic cover open with a small flat blade screwdriver (if you look closely you will see two small slots in the cover), then the whole console pretty much falls out of the headliner.
See this post from another forum: http://www.jaginfo.org/showthread.ph...l=1#post138734
JimC64
Sep 22, 2025 02:52 PM
1320racer
Oct 30, 2016 06:06 PM
