Rear wheel bearing/bushing? 2010 XF
Old Aug 18, 2021 | 02:40 PM
fredpribyl's Avatar
Default Rear wheel bearing/bushing? 2010 XF
My Drivers rear wheel wobbles a little when I changed tires today. Is it the bearings....bushings or something else?? Thank you
Fred
Old Aug 18, 2021 | 04:59 PM
coolabah's Avatar
Fred
I think more information is needed for diagnosis
The trick is to grab the (mounted, with car jacked up off ground) wheel and grab with hands at 6 and 12 oclock, see if it moves, then 9 and 3 o'clock , see if it moves . Look for play in all the bits attached to it- there should basically be none.
Old Aug 18, 2021 | 05:12 PM
fredpribyl's Avatar
Yes there is play.
Old Aug 19, 2021 | 11:41 PM
coolabah's Avatar
Yes there is play.
Oh, OK maybe I misread your initial post as you trying to work out exactly which part was failing rather than wondering if there was a problem at all. Yes , from the brief info you provided it does sound like it may be a bearing , bushing or ball joint. HTH
ZK686
Jun 10, 2021 01:11 PM
hoylegj
Jul 18, 2018 06:01 PM
iownme
Sep 17, 2015 07:30 PM
joey4420
Nov 26, 2013 01:33 PM
walkman1
Nov 16, 2010 11:47 AM
