Red Restricted performance and Red DPF Full warning
Old Jul 18, 2020 | 10:00 AM
Paulgb's Avatar
Angry Red Restricted performance and Red DPF Full warning
So have had my XF S 3.0D for 2 years and bar and alternator issue has be fine and have covered 50k since owning taking it to 103k. On way home Thursday and 20 miles into journey fairly fast 90-100mph and Red RP light came on, pulled over switched off engine and left for 10mins, checked oil and water (both fine) and restarted. Drove home and put code reader on and said it was Air mass correlation issue.
Have replaced both MAF sensors, cleared code. Took out for a run and after 5 mins taking it easy, started to accelerate on motorway and once it hit approx 3500 rpm went back to limo mode. Pulled over and same code had returned. Restarted to return home and Red DPF warning came on (never had any DPF warning previously)
Have also noticed a strange rushing air type noise (think from drivers side underload)
Anyone had this before and what was the outcome
Old Jul 18, 2020 | 10:50 AM
JagV8's Avatar
Be careful as you may be risking serious damage - your car has failed to regen so the DPF needs cleaning properly.
Check your oil has NO SIGNS of diesel in the oil and DO NOT drive at all if it has because engine destruction is quite likely at that point.
Old Jul 18, 2020 | 11:23 AM
Paulgb's Avatar
Checked the oil and no change or smell of diesel. Guessing the engine must be running rich due to restricted performance which has in turn clogged up the dpf. Going to get dpf cleaned but need to get it bottom of the Red Restricted Performance. Any ideas what could be causing that?
Old Jul 18, 2020 | 03:56 PM
George05's Avatar
Could be Turbo related or the dreaded cracked manifold issue , It is black plastic surrounds both sides of engine check it for cracks or splits
Old Jul 18, 2020 | 04:12 PM
George05's Avatar
What was the codes ?
Old Jul 18, 2020 | 05:44 PM
Paulgb's Avatar
cannot remember the actual number off top of head but listed as Mass Air Flow Correlation Issue
Old Jul 18, 2020 | 07:13 PM
George05's Avatar
Sorry I really tried to help now I got to back away good luck
Ash
Jun 29, 2022 03:38 AM
Roman the Austrian Swede
Nov 14, 2017 04:07 PM
tberg
Dec 17, 2015 07:15 PM
Thempsc
Sep 7, 2015 02:29 AM
yeldogt
Aug 22, 2010 07:34 PM
