Relay?
Old Jul 19, 2018 | 12:53 PM
snepo's Avatar
Default Relay? Electric Cooling Fan
My electric cooling fan is not working. Have no power to the fan. Is there a realy for the fan? And where can i find it then. The fuse is okey for the fan.
XF 3,0 Diesel 2011
Old Jul 20, 2018 | 03:57 PM
Bigg Will's Avatar
Well if it's like the Gas engines, their is no serviceable fan relay, only an electronic fan controller that is sold as one with the fan. From the petrol service manual,
"An electric, variable speed cooling fan is installed in a shroud attached to the rear of the radiator. The cooling fan is operated
by a fan control module, integrated into the electric motor, under the control of the ECM. An electrical connector at the RH side
of the shroud provides the interface between the cooling fan harness and the vehicle wiring."
Old Jul 21, 2018 | 09:29 AM
snepo's Avatar
Hi okey i found a electrical wiring diagram,and i didnt see any relay for the fan. Maybe its the sensor coolant temperature
Bowmanconsult
Jan 8, 2024 02:23 AM
JensenHealey
Feb 25, 2017 07:20 PM
NTL1991
XJ40 ( XJ81 )
Feb 29, 2016 05:56 PM
Saemetric
Dec 5, 2014 05:56 PM
Civicalized
Sep 1, 2011 11:40 PM
