Center brake light wiring location?
Old Jul 21, 2018 | 07:51 AM
h2opolo's Avatar
Default Center brake light wiring location?
Anyone know where the center brake light wiring is located? I’m trying to tap into it.
The photo shows a box near the 3rd light but after disconnecting the light still works. I’m guessing this might be for the defroster?
Old Jul 21, 2018 | 02:32 PM
h2opolo's Avatar
Default solved
Solved … according the manual which I downloaded here: https://www.dropbox.com/s/itzjq6rti2...p%20Manual.pdf
the entire deck lid has to be removed if you want to change the light. I just wanted to find the connector which is located on the passenger side behind the bolster...which is easy to pull out if you can drop your seat down (a mod I made earlier to allow for that, otherwise you have to unbolt the top of the seat).
After pulling the bolster you can access the wires which have a pulsator spliced into it.
Ubad2
Feb 18, 2018 11:01 AM
J8levi
Feb 19, 2015 11:45 AM
caldercay
Jul 10, 2011 09:30 PM
yeldogt
Mar 16, 2011 12:38 AM
hlgeorge
May 5, 2010 08:29 PM
