Anyone know where the center brake light wiring is located? I’m trying to tap into it.
The photo shows a box near the 3rd light but after disconnecting the light still works. I’m guessing this might be for the defroster?
the entire deck lid has to be removed if you want to change the light. I just wanted to find the connector which is located on the passenger side behind the bolster...which is easy to pull out if you can drop your seat down (a mod I made earlier to allow for that, otherwise you have to unbolt the top of the seat).
After pulling the bolster you can access the wires which have a pulsator spliced into it.
