Removing Adaptive Headlight
My MoT Tester picked up an insecure headlight problem, both mounting lugs were broken (I suspect it's been a problem for a very long time). I removed the light to repair it, there's a hydraulic connection and despite searches I have been unable to find out the proper procedure for disconnecting and reconnecting this hose. Can somebody pleae point me in the right direction? Spoiler alert, I went ahead and disconnected it, lost a small amount of fluid (what is this fluid, where is the reservoir, do I need to bleed it?
Many thanks in Advance, Malcolm
There are three Headlamps listed for the first generation XF:
Non H.I.D. to VIN S20752
H.I.D. from VIN S20753
The third type is significantly different.
Doh! I bet I do mean the hose to the powerwash jet! That's why I couldn't find anything about it . . . . . And they say there are no stupid questions :-) Thanks very much
Many thyanks,
Malcolm
Many thyanks,
Malcolm
Yes - prob the bi-xenon headlights on the 2010. It's the washer jet which is hidden behind the silver patch on the front of the unit
Those plastic tabs break easily. An easy and free fix - find a large metal washer and use that to replace the broken plastic tab
It's not a great design - as you tighten the headlamp screw it puts a lot of twisting pressure on that tab. I've had metal washers on mine for years and it's perfect.
