Revs high when starting
Old Feb 25, 2024 | 03:20 PM
ChrisO1971's Avatar
Default Revs high when starting
I have a 2013 jaguar XF3.0 all-wheel-drive supercharged. Recently it has started doing high revs. The only times it does it is after it is warmed up when restarting it. It varies each time. It will idle down after about 10 to 15 seconds. When I first bought the car about a year ago the engine light came on and I did a code read and it was for the mass airflow sensors. I cleaned them and it came back on so I replaced both of them. But it just recently started doing this rev upon warm motor start up. Any ideas would be great thank you.
Old Feb 25, 2024 | 06:34 PM
lotusespritse's Avatar
I had that problem with a 2014 RRS 3.0. It was a vacuum leak caused by the acoustic symposer (or whatever they called it). It would rev very high for about a minute and then settle down and drive normal. But it did give misfire codes as well. I disabled that silly symposer by fabricating a block off plate and the codes and idle issues went away immediately. If you don't have that system, it could be an air leak somewhere else along the intake. I have an automotive smoke machine that I used to find the problem. I read the same problem can also be cause by a torn EGR diaphragm, or a crack in the plastic valve covers.
Old Feb 25, 2024 | 08:16 PM
ChrisO1971's Avatar
Thank you i will look into that.
Old Feb 28, 2024 | 11:10 AM
kkurulak's Avatar
Had the same issue on my 2014 3.0 SC AWD, have you looked at this post below, I did a bit of a tutorial as to how I fixed my issue.
high revs/ lean bank 1&2 - Jaguar Forums - Jaguar Enthusiasts Forum
Old Apr 27, 2024 | 09:17 PM
ChrisO1971's Avatar
Default Replaced pcv cover
Replacement was pretty easy. Old one was ripped badly. Still have high revs on start up.
Old Apr 27, 2024 | 09:42 PM
Good thing you replaced it. Next, it’s time to break out the smoke machine.
Old Apr 27, 2024 | 10:03 PM
kkurulak's Avatar
Wow, That's a nasty rip. I would agree, if there was nothing else obvious when disconnecting and then during re-assembly, I would be looking at another leak somewhere.
I honestly would have thought after finding the ripped PCV diaphragm, replacement would have solved to.
Old Mar 8, 2025 | 01:59 AM
Can_value's Avatar
Hello, did you manage to solve the problem? Exactly having the same. Thanks
Old Mar 8, 2025 | 07:12 AM
ChrisO1971's Avatar
yes it fixed the problem. It took a day or two for the computer to read that I had a new PCV in it, but the car runs great now took me about 30 minutes to do it bought the part off Amazon.
Old Mar 8, 2025 | 07:14 AM
Can_value's Avatar
Sorry, what exactly help? Above you wrote that you changed PCV cover and it didn't help.
Old Mar 8, 2025 | 07:20 AM
ChrisO1971's Avatar
yes I posted to soon after i did replacement part. After driving it for few days it was starting normal and it hasn’t done it since
Tecnica
Feb 27, 2021 10:21 AM
dibbit
Feb 20, 2019 07:20 PM
michaelodonnell123
Feb 5, 2016 07:19 AM
Allan
Apr 3, 2008 07:26 PM
