Should I be worried?
Old Sep 21, 2014 | 11:05 PM
93905g's Avatar
Exclamation Should I be worried?
So I've had my car for 2 days now, man is it fun. I'm glad I went with the sc. My only concern is that last night I went to run some errands and out of nowhere I get a "transmission fault" message in the dash. I pulled over turned it off waited a minute then started it up again. The check engine light was on so instead of finishing my errands I just drove home. When I got home decided to google "transmission fault jaguar xf" and I came across this page called jaguarxfproblems.com I read it and decided to try something it said to do to check if you got a bad engine. (Rev it to 1000rpm n listen for some noise). Anyways when I turned the car back on and guess what no more check engine light. Is this common? I'm going to the dealership tomorrow I will mention it to the service advisor. Could it be cause I was driving it too hard? Idk but today I tried to replicate the results I drove it super hard (surprised I haven't got a ticket yet, knock on wood) and nothin just wasted a full tank of gas lol. Any and all input is highly appreciated. Thanks in advance.
Old Sep 21, 2014 | 11:51 PM
Canard's Avatar
I think the users of this forum would like a lot more information about your vehicle. Definitely worth getting investigated.
Now where I"m confused is that you said you were trying to "replicate the results," yet it happened "out of nowhere." This sounds a tad contradictory. I've seen Jags go into "limp mode' if you do something that could damage the engine. If you were using the Dynamic mode you could have done a variety of things that it just didn't like.
Old Sep 22, 2014 | 12:15 AM
93905g's Avatar
Oh sorry what I meant by out of nowhere was that I was just driving normally that time not flooring it or anything like I did the drive before that no sports mode or anything just regular D. So I thought maybe it was because of the pedal to the metal type driving I was doing before that messing with the sports mode, dsc button and checkered flag button. What I meant by trying to replicate results is that I drove it really hard flooring it and messing with the different modes again. Idk if that clarifies it a bit lol. By the way it's a 2010 xfsc.... Thanks for your input I really need to learn how to use the different modes
Old Sep 22, 2014 | 02:05 AM
Cambo's Avatar
Originally Posted by 93905g
....When I got home decided to google "transmission fault jaguar xf" and I came across this page called jaguarxfproblems.com I read it and decided to try something it said to do to check if you got a bad engine. (Rev it to 1000rpm n listen for some noise)....
Sorry I shouldn't laugh, but I had a look for that website you mentioned, and I found it Jaguar XF problems and reviews.
That site is owned by an ambulance-chasing law firm, they have dozens of sites like that for different makes/models. It's nothing more than a scare-campaign to try & get people in on class-action lawsuits so the lawyers can MAKE MONEY. Don't worry about it.
1. Chill out, relax, take it easy...
2. Take your car back to the dealer
3. Get them to read all the trouble-codes DTC's and give you a printout of them all BEFORE they start erasing them
4. Report back with what they've said
and 5. get yourself a codereader/scanner so that next time something like this happens you can plug it in & get the code yourself.
Really it could have been anything, like a stuck valve in the evaporative emissions system, or something equally innocuous...
Old Sep 22, 2014 | 08:12 AM
93905g's Avatar
I figured. Site seemed kinda fishy. As far as the code reader can you recommend 1 that works good with the xf?
Old Sep 22, 2014 | 10:02 AM
2010 Kyanite XFR's Avatar
I bought this one from Ebay and couldn't be happier. Then get the Torque app if you have Android (not sure the equivalent if you have Apple). I leave mine plugged in all the time and it never gives me any issues with the battery as I've heard other have had with competing products. Anytime I want to know what's going on with the car, I just pull up the app and all data is available to me.
Mini Black OBD2 OBDII Wireless Bluetooth Car Diagnostic Scan Tool Code Reader ? | eBay
Old Sep 22, 2014 | 12:25 PM
tbird6's Avatar
I want to get a BT one in addition to my wired ELM327. The wired one is in the way all the time.
The OBD port points strait down. Is the BT one out of the way so my legs and knees won't hit it?
Old Sep 22, 2014 | 02:52 PM
Mine is so thin that it takes a little effort to get enough grip to pull it out. And I have really long legs and have never noticed it. When I first got it I would pull it out. Then I forgot about if for two months and now never take it out since I haven't had any issues with the battery.
Old Sep 23, 2014 | 03:22 PM
tbird6's Avatar
Yes that's what I want to do to. Just plug it in and leave it in.
Old Sep 23, 2014 | 05:15 PM
Then the one I got would be perfect for you.
damienedwards
May 2, 2016 04:51 AM
thedugger1
Oct 16, 2015 10:06 PM
Mark SF
Sep 28, 2015 01:51 PM
Peeam
Sep 22, 2015 05:15 AM
Peeam
US Northeast
Sep 21, 2015 09:43 AM
