Steering Fluid
Old Mar 24, 2012 | 08:48 AM
Rique's Avatar
Default Steering Fluid
Hey folks, need to top up my steering fluid. No Mobil ATF320 PAS fluid any where. Can I use Dexron III? It seems Mobile ATF320 is exactly that.
These specs are from Mobile web page...
Mobil ATF 320 is recommended for use in applications requiring:GM Dexron III GMobil ATF 320 is recommended for use in applications requiring:GM Dexron III G
Mobil ATF 320 has the following builder approvals:
Ford Mercon M931220, Allison C4 (31574001) Voith G607
ZF TE-ML 4D, 17 C Mobil ATF 320 is recommended for use in applications requiring:
GM Dexron III Renk Doromat
Typical Properties
Mobil ATF 320 SAE Grade
Viscosity, ASTM D 445 cSt @ 100°C 8.2
Brookfield viscosity @ -40°C, mPa.s,
ASTM D2983 17900
Flash Point, °C, ASTM D92 197
Density @ 15 °C kg/l, ASTM D 4052 0.863 Mobil ATF 320 is recommended for use in applications requiring:GM Dexron III GMobil ATF 320 is recommended for use in applications requiring:GM Dexron III GMobil ATF 320 is recommended for use in applications requiring:GM Dexron III G
Old Apr 7, 2014 | 03:40 PM
Tanman's Avatar
Edit: Replied to wrong thread...sorry!
Old Apr 7, 2014 | 08:52 PM
BritCars's Avatar
Worth investigating why you need to top it up. Mine was low and I got a slight vibration in steering in icy cold weather. Turned out the power steering pump was leaking - replaced on warranty. Apparently not an unusual problem (same with the coolant pump apparently).
Old Apr 7, 2014 | 08:54 PM
BritCars's Avatar
Also - see this link
https://www.jaguarforums.com/forum/x...-fluid-115346/
Owner's manual suggests a Dexron III can be used if the Mobil isn't available
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
vwbusbits
Oct 13, 2015 03:43 AM
Poet
Oct 2, 2015 09:00 AM
Woznaldo
Sep 26, 2015 11:02 AM
reb1999
Sep 26, 2015 08:41 AM
