Subwoofer wiring diagram inside
Old Nov 10, 2013 | 08:17 PM
Gn4hir's Avatar
Default Subwoofer wiring diagram inside
I have the B&W premium sound system in my 2011. I'm not that impressed with the system. First step is to reinforce the mid to sub frequency with an aftermarket 10" sub.
We can't get a preamp analog signal because there isn't one, the digital MOST system for data goes to the stock amp. We have to take the processed speaker level feed from the amp and use an aftermarket amp that can accept this high level input.
There are two negative - and two positive + connections from the amp as the single speaker in the sub is a dual voice coil.
I bought the TOPlx wiring diagram so here is the sub wiring
You can take this from the amp or from the connection at the sub.
I'll post a picture when I actually have things mounted up.
Attached Thumbnails Subwoofer wiring diagram inside-subwooferwiring_zps259b0ca4.png
Old Nov 10, 2013 | 08:27 PM
patrickw813's Avatar
I'm looking forward to seeing your setup and results. The B&W system in the XFR leaves me feeling empty compared to the Meridian system in my Evoque.
DevonDavid
Jan 8, 2026 03:12 PM
Rivguy
Nov 13, 2022 02:55 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Daniel Howden
Sep 13, 2015 02:28 PM
danpop
XJ40 ( XJ81 )
Sep 8, 2015 03:23 PM
