Swapping out Engine
Old Sep 22, 2018 | 12:16 PM
Rique's Avatar
Default Swapping out Engine
I have to replace the headgaskets of my 2011 NA, after a plastic pipe failed and blew them. I am considering buying a good used engine and replacing rather than go through all the work.
Will the replacement of another engine require any computer programming or will it be plug and play?
Old Sep 22, 2018 | 02:31 PM
lotusespritse's Avatar
People just won't believe me that all those pipes have to be replaced as part of maintenance every 6-7 years. Another one bites the dust.
The correct answer to your question is: Sell your car for parts and buy another used one for about the same price of an engine replacement + the money you make from the sale of your old car. You'll never come out ahead changing the engine with all the headaches.
Then spend a $1000 on new plastic parts and change them before they fail.
Old Sep 22, 2018 | 02:46 PM
BritCars's Avatar
Sorry to hear that. Unfortunately if it's the 5.0 V8 you will find that even a used engine is very expensive. Prob nearly as much as the car is worth. And you don't know if it has issues too...
If you overheated yours then the block could be warped so it's likely more than a gasket
Would suggest you run the cost of all options incl Lotus' suggestion.
Old Sep 23, 2018 | 11:57 AM
kiddhan625's Avatar
Which plastic pipes are you referring to? Thanks
f_in_seattle
Jan 14, 2023 11:52 AM
Robert Gladding
Aug 1, 2017 08:45 PM
Fraser Mitchell
Dec 18, 2013 10:48 AM
pmdowd6
Dec 6, 2013 10:45 AM
tpro123
Dec 9, 2010 11:13 AM
