Ticking Sound on Full Lock
Hello, I have a 2015 Jaguar XFS 3.0 S/C AWD that doesn't see a lot driving. There was an issue with the supercharger coupler that was sorted at the dealership under warranty a few days ago. I drove the car back and everything was fine. Yesterday, I took it for a drive and heard a ticking/creaking sound coming into the cabin from the front right hand side of the vehicle. This sound only occurs when the steering is turned all the way to the right (Full lock) and noticeable only at very low speed.
- I inspected the sound while the car was in motion and there is no tire rubbing or anything loose (visually)
- Does not occur upon turning left (full lock)
- There is no vibration in the steering wheel just audible sound that is clearly evident int he cabin and outside
- I took the vehicle for wheel alignment and balancing, 3 wheels were off balance, alignment was perfect aside from a slight camber in the rear right side which apparently cannot be fixed, but too minor to worry about.
: That did not fix the sound
I have set yet another appointment with my Jaguar Dealership, but wanted to know what the cause for this sound might be in an attempt to figure out if it will be covered under CPO warranty or not.
PS The camber on the right rear wheel is about 1.58 degrees according to the tire shop tech. He also said that he can't see any uneven wear on the tire so its no biggie. My understanding is that ~2 degrees is quite significant....should I worry about it? Would the fix be to change the entire control arm (assembly) or and aftermarket camber adjustment kit.
Any suggestion and words of wisdom are appreciated!
Link: https://youtu.be/gEkguF1KhjI
Received 3,138 Likes
How regular or irregular is the sound?
Is it maybe once every wheel revolution?
If it is then it's probably something on the wheel touching something else or vice versa. I once had a similar ticking sound (but from the rear and nothing to do with the steering angle) and it turned out to be a balancing weight touching the outer edge of the brake caliper, the muppet who balanced the wheels stacked the wheel weights on top of each other rather than side by side.
But the first thing I would check is the wheels nuts, are they all done up to the correct torque (192 Nm).
Here's a link to the clip, let me know what you think.
I cant seem to catch a break. Today the trunk latch malfunctioned and needs replacing judging by the grinding sound its making.
The power steering was changed 4 months ago and had a different sound to what I was hearing this time around and it occurred whenever I turned the steering wheel in either direction and angle.
They charge you for inspection on CPO? That's strange. I've had both a used Jag and a used LR both with CPO, and never paid anything for inspection or covered work. Is that normal practice at your dealer?
Sounds like you've had a lot of problems for a 2015 vehicle. Mine is a 2010 model and aside from the water pump and power steering pumps under CPO years ago I've really not had anything go wrong
If it's the rubber boots then not very expensive (relatively) - although at dealer could be $500 or more. If the whole joint then a lot more but would then expect CPO more likely to cover
If they say CPO won't pay, ask them to go back and push / check as sometimes depending on how they describe the issue it might get coverage
I asked around other JLR dealerships in the province and all said the same thing.
The car has spent a total of 8 months (and counting, out of 20 months I've owned it) at the dealership for small to normal issues i.e seat cooling, camera, lumbar support, power steering, several coolant leaks, etc. My dad's XJL has faired better; my mum's F-Pace has been a total nightmare and my XF is in the middle in regards to needing repairs.
UPDATE. The dealership was not able to find any issue with the CV joints or control arm. I ended up going to my mechanic and he found the under body plastic shroud had warped at the right end and was rubbing against the wheel at full lock. He ended up cutting a tiny portion of the plastic and now the noise is gone.
WTB[UnitedKingdom]: Sepang 20 individual rims/tyres or full set, or full set 18/20 for X100
Diddion
07-24-2017 08:14 AM
hottienamedscottie
04-17-2009 08:41 PM
