Tilt Steering Wheel Noise
Old Jul 25, 2015 | 09:41 PM
Dick's Avatar
Default Tilt Steering Wheel Noise
There are a number of posts in the archives about Tilt Wheel not working properly, but I didn't see any about the Tilt Wheel working properly but making occasional noise.
When my tilt wheel lowers, it occasionally makes a short"groaning" or rubbing sound, which lasts about a second. It doesn't delay the tilt, it just makes a brief noise as it starts. It seems tobe when the car has set in the sun, or has been idle for several days. The ServiceManager says this is not uncommon when the car has not been used for a while.
Since it is random and a small percentage of the time, I'mprepared to wait until it happens regularly, or something breaks.
Anyone else have this symptom?
Old Jul 26, 2015 | 11:48 AM
kiddhan625's Avatar
I have the same issue and was given the same answer by the SA. I am sure once the car is out of warranty they will be more than happy to take care of it!
Old Jul 26, 2015 | 12:46 PM
2010 Kyanite XFR's Avatar
Was a common problem. Had my cover replaced under warranty and it's never been heard from again.
Old Jul 27, 2015 | 09:51 AM
Dick's Avatar
Thanks for the comments. I think it sounds more like a rubbing (cover?) than a gear noise, so will suggest this sometime before the warranty runs out next spring.
Old Jul 27, 2015 | 12:13 PM
Brutal's Avatar
The drive screws are dry dick. Tilt the wheel down, lift the sliding trim above the column that covers the gap between the i pack and column. Look inside and operate the motors. Youll see the drive screws, spray lube them well and noise gone, there are no parts needed
Old Jul 28, 2015 | 02:18 PM
davetibbs's Avatar
Mine makes a "groaning" noise when the wheel raises/lowers as I get in/out of the car. Is this the same problem (and therefore cured by the spray lube solution as well)?
Old Jul 28, 2015 | 05:01 PM
Brutal's Avatar
Originally Posted by davetibbs
mine makes a "groaning" noise when the wheel raises/lowers as i get in/out of the car. Is this the same problem (and therefore cured by the spray lube solution as well)?
yes, i thought that is what we were talking about
Old Jul 29, 2015 | 06:30 AM
jaguny's Avatar
I had this noise on mine, was told it was lubed. Done twice in 3 years of ownership, currently quiet
Old Jul 29, 2015 | 11:30 AM
Dick's Avatar
Thanks for all your replies. "Groaning" is probably the best description, altho mine only lasts a second, and only when it starts lowering. I'm headed out of town for a couple of weeks, but will definitely bring the suggestions to the Service Manager.
Old Jul 29, 2015 | 06:10 PM
jaguny's Avatar
Sounds similar to what mine was doing.
Old Jul 31, 2015 | 12:53 PM
tbird6's Avatar
Brutal would this also be the solution on the S Type since the XF and the S type are so closely related?
I am going to do it anyway.
Old Jul 31, 2015 | 03:29 PM
damienedwards's Avatar
Had a groaning noise too coming from the wheel when in easy entry mode..........quick lube of the said drive screws worked......thanks guys!!!
Old Aug 1, 2015 | 02:39 PM
Dick's Avatar
What lube did you use?
Old Aug 1, 2015 | 05:05 PM
Good thing you quoted the previous message...that reply on it's own would have been awkward.
Old Aug 1, 2015 | 07:48 PM
hen555's Avatar
Which lube do you guys recommend ? Even my steering whel makes this old nasty groan when I close the door and the steering wheel comes down. Louder when its been sitting in the sun for a while.
Old Aug 3, 2015 | 08:26 AM
Brutal's Avatar
It works on ALL the screw drive columns
Old Aug 4, 2015 | 12:02 PM
tbird6's Avatar
Good to know and thanks as always!
Old Aug 10, 2015 | 03:38 PM
Dick's Avatar
Drove about 1200 miles last two weeks, lots of sitting in the sun, pretty frequent groan. Stopped by the dealer today. Mechanic had not seen/heard the condition before, but lubed the drive mechanism. Will see if the noise reoccurs.
Old Aug 10, 2015 | 03:40 PM
Dick's Avatar
I forgot to say, thanks to all who confirmed the problem and recommended the solution - I was able to tell the SA that this was not an unusual problem.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
RobertTheBloke
Sep 24, 2015 11:48 AM
Burdedw
Sep 12, 2015 10:39 AM
innzane
Sep 2, 2015 10:08 AM
