Tires
My 13 XF 5.0SC will need new tires in the coming months. I am seeking opinions for new shoes that will wear better than the Dunlop SP Sport Maxx tires that came on the car, I don't really need the Ultra High Performance Summer tires. Any suggestions? Anybody have the Continental Extremecontact DWS tires?
Thanks for the suggestions.
Jeff
Jeff
I see you are in SoCal, so do you really need the DWS (Dry/Wet/Snow) version? The DW version is apparently much better for dry road grip and the tread pattern is completely different. I had the DWs on my old XFS and I really liked them, great grip dry and wet, good ride and low noise, but I didn't have them on long enough to comment about wear (upgraded to 20" rims).
Your sizing might be different, as my '09 XF wears 18" tires, however I installed a set of Bridgestone Potenza Pole Position RE970 tires on my XF 3 years ago. The car doesn't see a lot of miles, and I run snow tires during the winter, but so far, I'm impressed with these tires. I didn't care for the OE Continentals, and got rid of them after about 6-8000 miles. I like the handling a lot better with these Bridgestones.
Jeff
Jeff
I had the Hankook Ventus V12 evo's when I purchased the car. The were very nice highway tires but lacked the turn in and ultimate grip of the S-04's. I've heard the current version is better though so you may want to research them further.
At any rate, there is no reason to have all-seasons in So Cal unless you go to higher elevations in the winter.
Depending on your budget and how many miles you're looking to get our of your tires, I found myself quite surprised with the Delinte Thunder D7 tires I put on my XJ (Supercharged, 20" wheel setup). The dry/wet grip is good, and I currently have about 22K miles on them. I can get probably another 10K miles out of the rears, and the fronts have quite a bit more tread left. Compared to a set of Pirelli's which are good for about 8-15K per set, I'm very impressed with their longevity, especially given how inexpensive they are. I bought them as an interim set, but am seriously considering getting them again.
I went with the Conti DWS 06 when the Dunlop rubber cracked and the dealer offered to replace all 4 (pre-recall).
I have 15K on them now and they have a lot left and do have great grip in wet, and very good in dry. You lose a very little hot road grip but not enough in my opinion to worry about unless you drive at limit alot.
The DWS 06 tires are very good in my opinion.
