Unknown DTC Codes within XF Menu
Long time lurker, first time poster. Today my Engine Light came on and before I spent hundreds of dollars having someone else look at and repair it I wanted to see if it was something I could simply do.
I received the following DTCs within the menu:
https://imgur.com/a/to5zU3f
I am confused on what these are when most seem to start with a "P'.
Any assistance would be greatly appreciated.
DTCs beginning with 'P' designate Powertrain; 'C' is for Chassis.
Before getting involved with trying to sort out the DTCs, what is the age and condition of the battery? A failing or weak battery can cause random DTCs to set.
With the ignition in the OFF position for at least ten minutes, there should be a minimum of 12.6 volts across the terminals. If not, charge the battery overnight with a 2 to 10 amp charger and retest it the next day. If the voltage is still below 12.6 volts, the battery must be replaced.
Apologies. The vehicle is a 2014 Jaguar XF 3.0 Supercharged AWD with 51,500 miles on it.
I looked at the battery and got the below result.
https://imgur.com/a/EGGKXq9
I also went to AutoZone and they said that they got three errors all regarding the Oxygen Sensor but said I should get a second opinion as their machine also said the car was going 30 mph while parked.
Any assistance is greatly appreciated as I will openly admit that I am completely ignorant on the technical and mechanical parts of cars.
Thank You.
Thank You.
Also I can't think of any battery or egnine actions that could have caused it. I noticed it after doing a tight U-Turn in which the left driver tire "bucked" a little (for a lack of better words).
al_roethlisberger
Jul 28, 2024 12:00 PM
styper2003
Mar 31, 2020 05:08 PM
Rheys
May 1, 2018 04:45 PM
