Vacuum Leak
Old Jun 16, 2020 | 10:11 AM
Jaizero's Avatar
Default Vacuum Leak
Hello all!
First, I wanted to say how informative and helpful this forum is so thank you all!
I recently purchased a 2015 XF Sport 3.0 Supercharged (gas). I finally got around to plugging my scan tool into it and I found that the long term fuel trims in both banks are very high at idle (+18). I know from tuning domestics (U.S.) that this is not good, and usually indicative of a vacuum leak. There have been no warning lights, and no pending DTC on my scan tool yet. I tested around the engine bay with soapy water and propane with no results. Can someone clue me in as to where I should be looking? It seems to me that if both banks are high that the leak should be somewhere in the intake track before the throttle body, but I'm very new to Jaguar engineering so maybe I'm missing something?
Thanks in advance,
-J
Old Jun 16, 2020 | 10:20 AM
Jaizero's Avatar
Also to add, MAP kPa on my scan tool is reading about 35kPa at idle which also seems low and indicating a vacuum leak.
Old Jun 23, 2020 | 11:18 PM
Nedoerr's Avatar
Not sure about vacuum leak location, you have to determine that empirically. The plastic air intake cracks easily as it ages. I had to replace mine on my 2010 XJ last year. It had a small crack near the throttle body.
Did you already clean your MAFs?
Old Jun 24, 2020 | 01:32 AM
John Williams's Avatar
Carry out a smoke test, should show any leaks, the plastic manifolds often crack.....look for oil misting!
Old Jun 25, 2020 | 02:12 PM
Jaizero's Avatar
Sorry for the very late reply. I did find the plastic part around the throttle body deteriorated. It essentially fell apart when I removed it from the throttle body. New intake has been ordered.
Thank you!
Old May 12, 2024 | 10:54 PM
Jdabs's Avatar
Thank you!
Hi, my car is having this same issue, and I can’t seem to find a vacuum leak, did you ever find out this issue with your car? Thank you
Old May 13, 2024 | 10:12 AM
User 42324's Avatar
The answer is in his post that you quoted.
Old May 18, 2024 | 04:33 PM
bydand's Avatar
Just to make it a little clearer. (hopefully)
The plastic air inlet duct, (The plastic piece around the throttle body,) which has a stainless steel clamp ring (jubilee clip) which clamps the air duct to the throttle body has a tendency to absorb heat from the water pump directly below, and cook this plastic collar duct fitting to the metal throttle body. Resulting in the degradation, (breakdown) of this plastic collar which on break down allows excess air into the engine.
While the inlet throat, has a bitumen and alloy heat resistant collar above the water pump, the clamping ring to the throttle body, does not. Hence the overheating, and break down of the air inlet duct where it attaches to the throttle body due to over heating.
A little wordy, but the original statement was not that clear to me.
You just got to know Ali express, makes them for a reason!
https://www.aliexpress.com/item/1005...Cquery_from%3A
fvierra27
Sep 29, 2025 10:51 PM
944xjs
Aug 11, 2017 01:55 PM
steve_k_xk
May 31, 2017 12:47 AM
Cambo
General Tech Help
Apr 19, 2014 10:16 AM
e21pilot
Apr 9, 2010 06:48 AM
