vacuum line 2009 XF 4.2 na
Old Feb 5, 2024 | 08:23 AM
captron1's Avatar
Default vacuum line 2009 XF 4.2 na
Friends, I'm replacing the coolant outlet pipe on my 2009 XF 4.2 NA. There are vacuum lines coming off back of throttle body that appear to run thusly...one to a black cannister mounted by the fuse box, and another to the fuel sensor that also tees off to another location not yet found. These lines are tiny plastic lines that are as brittle as uncooked spaghetti and yes, I have snapped one off. The fitting to the back of throttle body is to a boot with both lines. There is a part # tag on the line but it does not correlate with a vacuum line per internet searches. On one side, the tag says 8X23-9S442-AC and on the other side it says S3JJA. So.....what are these lines? What are they for.....Where do I get them? Will the car run without them( dumb question I know)?
Old Feb 6, 2024 | 06:28 PM
gumby7734's Avatar
??? Google search is your friend, use that number to search, you can get from various sources, some on eBay right now...
Old Feb 6, 2024 | 07:37 PM
gumby7734's Avatar
They will affect your fuel trims...I replaced mine quite a while back...very brittle breathe on them hard and they break...
Old Feb 7, 2024 | 02:16 PM
captron1's Avatar
I've already fixed the car. Coolant leak done, vacuum line done. I know about google, but the exact vacuum line part description is conflicting with numerous others....Forget it, went to Napa, bought $2. worth of rubber hose and made a sleeve over the two ends. Voila.
Old Feb 7, 2024 | 04:03 PM
xalty's Avatar
black canister line is SAI
dfatherree
Apr 15, 2023 11:43 PM
Skedaddle
Apr 8, 2023 01:17 PM
RFG
Jun 19, 2021 11:01 AM
alatoni14
Aug 27, 2018 08:40 AM
Oscuridad
Jul 20, 2017 08:32 PM
