Warning Lights
Old Feb 7, 2018 | 04:06 PM
Art's Avatar
Art
Default Warning Lights
I put on a set of snow tires with non Jaguar rims. Warning message says "Tire Presure Fault". How do I shut this off. I have a 2010 Jaguar XF.
Thanks,
Art
Old Feb 7, 2018 | 05:09 PM
OzXFR's Avatar
It's a TPMS (Tyre Pressure Management System) message.
I'm guessing you didn't get the TPMS valves/senders swapped over to the new rims, and the system is throwing a hissy fit coz it can't see the senders any more.
Three solutions - get the valves swapped over, get a new set of valves and have them put on (they have to be OEM valves of the correct frequency, two different frequencies, not sure which yours is, they are quite expensive, you can get after-market ones much cheaper but most find them very problematic), or get the system disabled entirely which requires a knowledgeable operator with all the correct SDD gear and no dealer will do it.
BW_Hunter
Jul 29, 2017 07:16 PM
henry k
Oct 12, 2012 05:54 PM
JLee
Oct 6, 2012 09:46 AM
charger12
Apr 4, 2012 04:23 PM
