Water pump replaced at 16300k
Old Sep 5, 2014 | 10:32 PM
jaguny's Avatar
Default Water pump replaced at 16300k
As a point of info to others, my dealer just replaced my water pump when I brought it in for its annual service. They said there was visible moisture on the pump. Only 16300k miles, 2011 XF SC. Other than the creak of the steering column on entrance/exit auto adjustment and squeaking door seals, no other issues. I did ask them to check the pump given info from other forum members but was told they would have done so regardless.
Old Sep 13, 2014 | 07:54 PM
Rdyoung's Avatar
You were lucky to get 16.3 million miles out of it ...
Old Sep 14, 2014 | 01:43 AM
calviroman's Avatar
Common. There was a TSB for water pump seepage, many of us had our pumps replaced under warrantee.
Old Sep 14, 2014 | 09:14 AM
jaguny's Avatar
Just thought I'd add to the database; good catch rdyoung, need to type carefully! It's good to know others are reading carefully!
Old Sep 14, 2014 | 12:21 PM
aliensporez's Avatar
Mine was replaced last month at 33K miles. The tech told me they are a common failure in the XF.
Sprayall
May 30, 2021 08:13 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
Sprayall
Sep 3, 2015 07:49 PM
KarimPA
Sep 3, 2015 07:32 PM
