what spark plugs to use on a 09 xf 4.2
Old Jan 26, 2015 | 11:32 AM
PopokI09XF's Avatar
Default what spark plugs to use on a 09 xf 4.2
Hey guys, I have 93,000 miles on my 09 XF and it is going to be time for me to change plugs soon. I have been looking at the MSD #3725 plugs to put in because I just had good look with MSD on my 68 Cougar. But what guys out there used and what is the normal gap settings on the plugs??
thanks,
Chris
Old Jan 27, 2015 | 10:37 AM
JagV8's Avatar
I suspect OE are NGK IFR5N10 iridium. They're pregapped; do NOT use a feeler gauge on them as they're super-delicate. Good for 100K miles on my engine which yours essentially is.
Old Jan 27, 2015 | 11:48 AM
Mikey's Avatar
Whatever experience you had with ignition systems on a '60s car is not really comparable or relevant to a modern car.
Experiment with aftermarket stuff if you want- it's not going to work better than the OEM hardware.
Old Jan 27, 2015 | 02:07 PM
tbird6's Avatar
I also use the factory Iridium plugs from NGK in my 2005 STR.
Changed them at 95K miles and no problems currently at 110K miles.
Old Jan 27, 2015 | 06:15 PM
Mr Sharky's Avatar
I also recommend the NGK Iridium plugs for use on the XF. I have heard also that the top of the line Bosch plugs are just as good. I have used the MSD plugs on my hot rods with good results. But I have never tried them on my luxury cars. I tend to use the factory recommended stuff on them. But if many have tried one brand or another with good success, then I am open to trying them.
Old Jan 28, 2015 | 12:02 PM
PopokI09XF's Avatar
thanks I will probably go with the OE plugs since they are cheaper than the MSD Iridium plugs. I just wanted to see if anybody ventured out to other styles of plugs.
Old Jan 29, 2015 | 02:29 AM
whyhellothere's Avatar
NGK W0133-1631727 | Partsgeek.com
freakin' awesome.
cissdm
May 3, 2016 06:02 AM
BathoryFan
Sep 15, 2015 05:04 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
mrplow58
Sep 9, 2015 11:27 AM
