What? Squeaky brakes?
Old Sep 11, 2013 | 06:33 PM
jfintexas's Avatar
Default What? Squeaky brakes?
Just had my rears replaced and now have a squeaking after their hot as I approach a stop. Anyone else have squeaky brake syndrome? Is there a "break" in period? ---no pun intended :-)
Old Sep 11, 2013 | 07:19 PM
DPK's Avatar
DPK
Who and what did you have put on?...Dealer's Brakes or some other's?
IMPO..sounds like some cheap POS pads or some half-*** job or both..i.e., lacking vibration shims, no cleaning of calipers/mounts, lacking lubricant, a number of things causes brake squeal...Mostly cheap ones do it.
Old Sep 11, 2013 | 07:22 PM
jagular's Avatar
Yes, break in is required for brakes.
Many people don't apply their brakes hard enough to break them in properly and squeal results.
How long ago were your pads replaced? Did you also get new rotors ?
Did you use Jaguar pads?
Did you use a competent shop?
Old Sep 11, 2013 | 07:25 PM
jfintexas's Avatar
Dealer did the work 3 weeks ago. OEM pads. Rotors were fine so did not replace them. 2010 with 27k on the clock.
Old Sep 11, 2013 | 07:32 PM
jagular's Avatar
Better to have replaced the rotors. They likely won't last the full new pad life but too late now.
Trouble with reusing rotors is they need to be skimmed to ensure the new pads evenly deposit material on the rotors or smoothest braking. Skimming reduces rotor life.
I recommend you go out onto a conveniently lightly travelled road and perform a series of medium brake pressure braking events from highway speeds to bed in the new brakes. Don't get the new brakes hot just work them reasonably hard and smoothly and consistently to bed them in. Then drive normally for at least 500 miles. Then go out and hammer the brakes hard for half an hour or so. That should get rid of the squeal.
Google Stop tech brakes and read their technical papers. They're good.
Old Sep 12, 2013 | 03:36 PM
jfintexas's Avatar
Thanks for the tips. Will definitely exercise them.
PMKimpton
Aug 3, 2019 08:22 PM
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
wannajag
Sep 22, 2015 08:29 PM
Jefro
Sep 15, 2015 01:44 PM
