What is a VIM Modulator on XF Supercharged?
Old Jan 14, 2020 | 08:11 PM
kenmicn's Avatar
Question What is a VIM Modulator on XF Supercharged?
Hello,
I just had a repair for the VIM Modulator? And the repair shop said they had to download the code for the key fobs?
Can I get a simple explanation for what the VIM is, and why it fails, and the need to program the key fobs?
Thanks....
Old Jan 14, 2020 | 08:34 PM
BritCars's Avatar
Not a KVM by any chance? Keyless vehicle module. It's the module in the car that is paired to the keyless entry keys. It had to be programmed to match the keys
On newer cars for security it can't be reprogrammed and has to be replaced with matching keys I believe
Old Jan 14, 2020 | 11:11 PM
OzXFR's Avatar
Originally Posted by kenmicn
Hello,
Thanks....
There is only one mention of "VIM" in my copy of the 2010-2011 XFR Workshop Manual, and it's worded:
"General Information - Diagnostic Trouble Code (DTC) Index DTC: Steering Column Lock Module (VIM)
Description and Operation
Steering Column Lock Module (VIM)".
Of course absolutely nowhere does it say what VIM stands for or means!
Here are the two pages from the Workshop Manual:
Edit - I suspect it might mean "Vehicle Immobilizer Module" seeing as it relates to the steering column lock.
File Type: pdf
Old Jan 25, 2020 | 03:08 PM
kenmicn's Avatar
Thanks; they had to reprogram the keys....
Old Jan 25, 2020 | 03:09 PM
kenmicn's Avatar
Yes; they had to reprogram the keys....
Old Sep 20, 2021 | 02:11 AM
Daniele250389's Avatar
Default info
Good morning! I'm new to the forum! Can I ask you why did you have to replace the VIM? what problems were you having? I also had a problem with an error code on that module ... that is the error B100D-87 and the car did not give authorization to start. I had to disconnect the battery for 10 minutes and then it started! thanks in advance for your help! I would like to know if it is my same problem so I change the module too.
03xk8
Feb 23, 2021 07:24 AM
Godspeed
May 11, 2019 09:16 AM
mhamilton
Feb 5, 2019 09:51 PM
scardini1
Oct 20, 2014 05:01 PM
ixj8it
Nov 7, 2012 11:45 PM
