View Poll Results: Which wheels?
Niche Surge
0%
Lexani R3 - Black with CNC
50.00%
Lexani R3 - Machined
25.00%
Lexani R4 - Black with CNC
0%
Lexani R4 - Machined
25.00%
Multiple Choice Poll. Voters: 4. You may not vote on this poll
Wheels that fit the XFR
Old Aug 6, 2014 | 12:00 PM
nate96's Avatar
Default Wheels that fit the XFR
I am needing new rims as I have bent a the factory rims. What a pain in the *** this has been trying to find ones that will fit. I have contacted numerous vendors and manufacturers to find ones that will fit. Hopefully this list will help someone else out when looking. This is not a complete list, so if you know of others that will fit please add to it.
Wheels I am considering: (Sorry for the crappy photos)
Poll 1
Niche Surge
Poll 2
Lexani R3 Black with CNC
Poll 3
Lexani R3 - Machined face
Poll 4
Lexani R4 - Black
Poll 5
Leaxani R4 - Machined
Wheels that fit as well
Braelin
Br02
BR04
Giovanna
Lindos
Mecca
Yerevan
Lexani
CSS8
R3
R4
R6
R7
MR107
Niche
Circuit
Essen
Milan
Milan 134
Surge
Targa
XO
Monaco
Old Aug 6, 2014 | 01:36 PM
XJL's Avatar
XJL
1. Niche Circuit but with a chrome finish (if available)
2. Niche Essen
3. Don't like any others
Old Aug 6, 2014 | 07:51 PM
jaguny's Avatar
I have Savini BM3's I'm my SC. They and other Savini's may fit also.
Old Aug 7, 2014 | 12:04 PM
nate96's Avatar
2. Niche Essen
This might be a generation thing but I am not a fan of chrome. I actually have changed all the chrome to black on my car.
I did have a look at the Savini wheels. It seems that most will not work as they use a step up barrel for the rim. This interferes with the caliper. The BM3, BM4 and BM7 should fit. I have not received confirmation that it will.
BM3
BM4
BM7
Old Aug 7, 2014 | 06:57 PM
OzXFR's Avatar
Have you considered Coventry Whitley?
They are made specifically for Jag, including the XF, so the PCD and offsets are correct.
I fitted a set of 20" x 10" rear and 20" x 8.5" front a couple of months ago and they look great. I'm a fan of multispokes, chrome look outer rims and a bit of dish, and these ring all of those bells.
Website is here: Jaguar Wheels by Coventry. Custom X-type wheels, S-Type wheels, XF wheels, XJ wheels, XK wheels
Several stockists in the US.
And here's a pic with them fitted: https://www.google.com.au/search?q=c...sp%3B640%3B480
(not my car but you get the picture!)
Old Aug 7, 2014 | 08:33 PM
2010 Kyanite XFR's Avatar
I live very close to Savini and could have them test fit on my XFR if needed. And it's not just you... they aren't making the chtrome anymore. Called when I was researching my bent rim situation and they didn't have full sets.
Old Aug 7, 2014 | 09:34 PM
Mulmur's Avatar
Yes, these.. made for Jag's.. I had bought a set of Coventry wheels for my previous XKR to mount snows.
Lawrence.
Old Aug 8, 2014 | 06:17 AM
jaguny's Avatar
This topic would make a good sticky note as everyone who wants aftermarket wheels goes on the hunt.
Old Aug 8, 2014 | 01:53 PM
Donk's Avatar
Here's what I did
https://www.jaguarforums.com/forum/x...wheels-116116/
Old Aug 10, 2014 | 03:56 PM
nate96's Avatar
I'll add these to the list when I get some time. I am not really a fan of them. They look good, just not what I am wanting.
How is Adelaide? I spent some time there a long time ago haha (17 years ago)
Thanks for the offer Kyanite. For myself the ones that I like do not fit the XFR.
Originally Posted by Donk
I read your post before, it was helpful. The problem I have is that I am worried I would order wheels that even with shaving the caliper down that they would still not fit. I have been trying to get measurements from the manufacture of the inside diameter of the barrel so I could see if they would fit, but it has been a no go on their end.
Old Sep 20, 2014 | 06:35 AM
jagmt's Avatar
Ats racelight
20x8.5 et38 can this fit the massive r calipers?
Old Sep 20, 2014 | 01:28 PM
nate96's Avatar
Originally Posted by jagmt
Ats racelight
According to their website they will not fit the R but will fit other XFs with smaller calipers. Best to contact the manufacture directly. That is what I have been doing.
Old Sep 20, 2014 | 07:36 PM
jagmt's Avatar
I have sent ats email to ask for the fitment but haven't got a reply.
But I have a reply from 1 ebay seller that this will fit without issues. 4 x 20" ATS Racelight Jaguar XFR 2009 to 2014 Alloy Wheels 1390920241-46 | eBay
Old Sep 21, 2014 | 12:42 PM
nate96's Avatar
I bought a set of Lexani R3 that Lexani said "guaranteed fitment" and did not fit. I am just in the process of sending them back. I would make sure that they fit before purchasing off of Ebay. Can you get the seller to measure the inside of the barrel. I am going to measure this as the R3 just touchs the caliper.
Old Sep 22, 2014 | 08:34 AM
jagmt's Avatar
have gotten the reply from ATS. they confirmed that the wheel will fit without any issues.
but im thinking the same. to have the internal diameter measured then compare against with the oem ones
Old Sep 22, 2014 | 09:02 AM
nate96's Avatar
Comparing them to the OEM does not work. The OEM are built differently to provide the clearance.
I measured the inside diameter of the barrel of the R3 as they just touch the caliper. It is 17 3/4". You will need a wheel that has a bigger diameter than that in order for them to clear.
Old Sep 23, 2014 | 05:31 AM
jagmt's Avatar
just confirmed that the ats wheel wont clear. its measured at 42mm
Old Sep 23, 2014 | 10:09 AM
nate96's Avatar
42mm is the offset. The factory fronts are 20x8.5" with 49mm and rears 20x9.5" with 66mm offset. This will make the fronts stick out 7mm further and the rears will stick out 11mm further. Both wheels give more clearance on the inside. The only problem with some wheels is the design. A higher offset pushes the wheel further into the car creating clearance issues. As long as the wheel maintains that minimum clearance then it will fit.
Old Sep 23, 2014 | 10:30 AM
lotusespritse's Avatar
It's pretty impressive what they can do to fix bent wheels these days, and it will cost a lot less than replacement of all 4. Also, it's not hard to find a single matching wheel on eBay for sale cheap. But if you just want an excuse to change the wheels, a bent rim is as good as any.
Old Sep 23, 2014 | 11:14 AM
nate96's Avatar
It is true that many wheels can be fixed. I have had a few repaired. In this case the wheel was too damaged to be repaired to factory specs. When I took it to a guy to get repaired he had another set of the same wheels he was doing. He was telling me that the Jag wheels are terrible to try and repair. They like to hold their shape and once bent it is hard to get them back. I also had the developer agree to replace all the wheels as I hit a pot hole as it is cheaper than buying 2 Jag wheels.
