wheels offset
Old Aug 31, 2014 | 11:04 PM
jagmt's Avatar
Default wheels offset
is 18x8.5 +22 possible fitment to the XF? will it need fender roll?
Old Aug 31, 2014 | 11:39 PM
Cambo's Avatar
Welcome to the forum jagmt, when you get a moment stop by our new members area and introduce yourself ==>> New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
The stock offset for the 8.5" rim on the XF is ET49, if you went to an ET22 then that's pushing the wheel out 27mm, pretty sure you might have issues with rubbing...
Old Sep 1, 2014 | 12:13 AM
TMack's Avatar
For 8.5" width, 35mm is as aggressive as you can go without sticking out. 22mm will look bad even if you don't rub.
Old Sep 1, 2014 | 12:51 AM
jagmt's Avatar
thanks for the info.
i wanna achieve the flushed look and i could use this as a guide. if i choose to have a 9" width, does it mean the offset gotta be like 40mm?
Old Sep 1, 2014 | 06:40 AM
jaguny's Avatar
Jagmt, there is a tire rim calculator on this forum under the tools menu. Enter your current info and your after info and you will get the info on the changes. You can use this a guide. There are some better ones that actually illustrate the change. You can then check measurement on your car to see the impact. Are you buying new wheels?
Old Sep 2, 2014 | 07:34 AM
jagmt's Avatar
im not a very technical guy
yes im changing my wheels for the xfr brakes to fit onto my xf. i was just thinking that the 27mm would barely just make it if there is a big camber setting. maybe
H20boy
Dec 24, 2024 03:23 PM
Forcedair1
Feb 19, 2020 01:51 PM
PMKimpton
Aug 3, 2019 08:22 PM
DustysSon
Sep 13, 2015 04:17 AM
ferraripete
Sep 10, 2015 01:24 AM
