Will a 2014 Gear Selector work on a 2011 XF?
Old Jan 8, 2018 | 03:54 PM
sudo911's Avatar
Default Will a 2014 Gear Selector work on a 2011 XF?
Hi Guys,
The gear selector has gone belly up on my 2011 XF-S (gets stuck in gear and wont allow rotation to select gear) - so was going to replace it with a newer version i.e. one from a 2014 model. I'm assuming this is a direct replacement fit wise, but anything to be aware of (other than its aesthetically different).
kind regards,
Rowan.
Old Jan 8, 2018 | 05:56 PM
carzaddict's Avatar
i think it should. i know they've replaced mine with a 2012+ model
Old Jan 9, 2018 | 03:00 AM
elviukai's Avatar
It will work(gears will change) but "Gearbox fault" and "special modes are not available" will be displayed.
Old Jan 9, 2018 | 04:57 AM
sudo911's Avatar
Ah perfect, thanks. I was just trying to see if there was a newer version of the GSM module which had better quality.
Do you guys know what the correct part number would be for my car? 2011 XF-S 3.0 diesel.
snooktarpon
20
Feb 17, 2021 08:27 AM
vsol
Mar 24, 2016 07:37 AM
SkipM
Nov 25, 2011 02:16 PM
lincjag
Mar 1, 2009 01:37 PM
lovethemcars
Mar 11, 2008 04:54 AM
