XF 2WD Front Hub/Bearing Torque Spec
Old Jul 10, 2019 | 05:06 PM
index1489's Avatar
Default XF 2WD Front Hub/Bearing Torque Spec
Does anyone know the torque spec for the 4 bolts that mount the wheel bearing/hub assembly? 2013 XF 3.0 2WD
I also can't find the part number on these bolts, are they only available when you order the replacement assembly?
*Edit was able to find the bolts PN C2P7441 x4, still looking for the torque spec!
Thanks!
Old Jul 10, 2019 | 09:18 PM
OzXFR's Avatar
My copy of the 2010-2011 XF 3.0D Workshop Manual says, for the front suspension: "Wheel hub and bearing assembly to wheel knuckle retaining bolt 90 Nm / 66 lb-ft".
I presume this is the correct description of the four or five bolts you are talking about, and it is 99% certain this would not have changed between the 2010 and 2013 models.
Old Jul 10, 2019 | 09:53 PM
index1489's Avatar
Yes those are it, Thanks!
atrier3
Apr 15, 2015 02:29 AM
Tel
Apr 11, 2015 06:59 PM
eriklane
Dec 17, 2014 06:41 AM
blackcat
Dec 3, 2010 10:35 PM
rdcsat
Nov 16, 2007 06:20 PM
