Xf coolant/water pump leak common on 5.o
Old Apr 18, 2013 | 03:42 PM
dannygjatt's Avatar
Default Xf coolant/water pump leak common on 5.o
I took my 2011 5.0 XF in for service and had some of the retaining clips, etc replaced from sunroof. I realize the sunroof noise is common on these vehicles. During the inspection, they found the coolant to be leaking, so they did a coolant leak inspection and found that the water pump is leaking. They went ahead and replaced it. I am getting concerned as my vehicle warranty will be up in 2015. If I purchase the extended warranty, will issues like this be covered? Any advice would be helpful, thanks guys!
Old Apr 18, 2013 | 05:49 PM
hlgeorge's Avatar
When purchasing an extended warranty you will have many levels to choose from. It's a little early to worry about an extended warranty, I'd just cross that bridge when the time comes.
Old Apr 18, 2013 | 07:43 PM
dannygjatt's Avatar
I agree, but it's probably worth it since there are problems this early.
Old Apr 18, 2013 | 10:22 PM
hlgeorge's Avatar
Usually if it there is a problem, it will show up in the first couple of years. Remember when cars had a 1 year, 12K mile warranty. People usually kept the cars longer too. I really appreciate the warranties offered today!
Old Apr 18, 2013 | 10:49 PM
Escolar's Avatar
Actually, extended warranty prices have several price jumps as milage increases. Varies with the warranty company, but if I remember right, the stuff quoted by Momentum Jag in SW Houston had increases at 24kmi and 36kmi, and they were non-trivial increases. If should shop around now if you are really interested.
silkcat
Jan 18, 2025 04:29 AM
bamforp
Aug 14, 2024 05:36 PM
Jandreu
Jun 30, 2022 03:10 PM
Russ Graber
Feb 23, 2019 11:59 AM
jaggermang
Sep 8, 2015 07:07 PM
