XF Front Door Glass Removal (Tool)
Old Sep 15, 2015 | 09:56 AM
mrsimpson's Avatar
Default XF Front Door Glass Removal (Tool)
In order to replace the lock it is necessary to first remove the glass using tool 'door glass release lever' 501-114, shown attached (then swing the glass guide out of the way to make access for the latch). I am having no luck sourcing the tool - it is listed here: https://jlrequipment.service-solutio...px?SKU=501-114, but this is a trade only supplier
It is only a bent strip, so I assume I can easily make the tool, however does anyone have any dimension or details of the end which releases the plastic clip holding the glass.
Any help/ glass removal tips appreciated. Thanks
Note I am aware that rear door lock removal does not require glass removal - the front is not so simple!
Old Sep 15, 2015 | 10:06 AM
danke's Avatar
Check this out and see if it helps: https://www.dropbox.com/s/rdpteii7fp...moval.pdf?dl=0
Old Sep 15, 2015 | 01:10 PM
mrsimpson's Avatar
Thanks Danke, but I have got the manual - it is the details and use of the tool that I am hoping for.
99xk8guy
Sep 29, 2025 10:51 PM
PMKimpton
Aug 3, 2019 08:22 PM
philwarner
Sep 5, 2015 10:05 AM
bdboyle
Sep 4, 2015 06:16 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
