XF SC 5.0 timing chain components
Old Oct 13, 2018 | 12:54 AM
keithbradley's Avatar
Default XF SC 5.0 timing chain components
I'm preparing to do timing chains/guides/etc. on my 2010 XF SC. Does anyone have a suggestion for sourcing parts? I'd like to get everything I need before starting the job so I'm not hit with any surprises.
Old Oct 13, 2018 | 01:38 AM
OzXFR's Avatar
davetibbs is your man, see this thread: https://www.jaguarforums.com/forum/x...ebuild-177468/
Old Oct 13, 2018 | 10:57 PM
I'm familiar with the (awesome) thread and sent him a PM regarding this matter a while back. I haven't seen him on here in a while though.
Old Oct 15, 2018 | 01:42 PM
Bigg Will's Avatar
Absolutely!
Old Oct 15, 2018 | 05:11 PM
clubairth1's Avatar
Community Influencer
Are going with the updated 8mm chains?
I think that's all you can get anymore?
Old Oct 15, 2018 | 09:09 PM
I'm not sure. Obviously there are a few more things to replace that way, but I'm open to whatever. It seems that the guide/tensioner contact point is more of an issue than the chain size, but if needed I'm swap to 8mm.
Old Oct 16, 2018 | 12:02 PM
clubairth1's Avatar
I think it's all in a package? That's why I was asking as we have had posts indicating Jaguar has superseded all the old 6mm stuff which includes the guides/tensioners.
So if you order the old 6mm part numbers they will send you all the newer 8mm stuff instead because the old 6mm parts no longer exists.
Old Oct 16, 2018 | 10:00 PM
I haven't been able to find a package yet. I found one for the range rover 5.0 and emailed the company (british atlantic) and got one response saying they would look into it and get back with me, followed by silence.
Do you have any good sources/links? I'm close to just going to the dealer and buying everything piece by piece, but I'm sure if I do that I'll be without something I need.
Old Oct 17, 2018 | 07:02 AM
Bigg Will's Avatar
Well the Range and Jag 5.0 are exactly the same internally.
Old Oct 17, 2018 | 11:50 AM
clubairth1's Avatar
Hi Keith;
Have you looked at this thread?
As has been posted DaveTibbs has done a TON of work on 5.0L V-8's and I doubt anyone outside of a dealer tech or maybe Cambo will you find someone with more knowledge!
Chains
Maybe look at this one too?
5.0L Timing
motorcarman
General Tech Help
Aug 4, 2020 02:22 AM
slanham
General Tech Help
Feb 1, 2014 06:34 PM
kdross
Sep 9, 2010 08:08 AM
