xf screen washer
Old 01-19-2015, 11:27 AM
cliff ball's Avatar
Default xf screen washer
hiya can any one help me with ideas on problem washer jets on a 2009 xf .they work great when engine not running with ignition on but when engine running only sprays once. have checked pump and cleaned out bottle and filters and connections seem ok to pump PLEASE ANY IDEAS OUT THERE??
Old 02-08-2015, 12:10 PM
cliff ball's Avatar
Default washer jets
all sorted now found pipes partly blocked and pump overheated and cut out .cleaned all pipework and fitted new pump also not using any cleaner in bottle just plan water .
Old 02-08-2015, 09:19 PM
hlgeorge's Avatar
Glad you found it! I would use the washer fluid made for auto washers, It will keep the water lines clean and also acts as an antifreeze.
Finbarr1975
09-16-2023 02:52 PM
sunchip
10-05-2015 02:05 PM
Finbarr1975
10-04-2015 05:32 PM
10 XF Premium
10-02-2015 09:22 PM
Quick Reply: xf screen washer
