XF Servicing Due reset
Old Oct 5, 2012 | 11:56 AM
licknstick's Avatar
Smile XF Servicing Due reset
does anybody know how to reset the service manager on a 2011 xf?
Old Oct 5, 2012 | 01:47 PM
BigCat09's Avatar
Resetting the service light on a Jaguar XF
Press and hold the rear lamp switch (while the ignition is on).
Press the start button without applying the foot brake.
Release the rear fog lamp switch.
Press and hold the trip computer cycle switch.
Press and hold the rear fog lamp switch.
Continue to hold the trip computer and rear fog lamp switches.
The message center should display "resseting service mode" and then "service mode reset"
Release the trip computer and the fog lamp switches and turn the ignition off.
Old Oct 5, 2012 | 02:12 PM
licknstick's Avatar
If I press the start stop button without applying the brake whilst whilst the ignition is on wont this switch everything off?
Old Oct 5, 2012 | 05:35 PM
BigCat09's Avatar
Reverse that step. Its the other way around.
Old Oct 6, 2012 | 08:20 AM
licknstick's Avatar
So what do I need to do?
Old Oct 6, 2012 | 12:41 PM
licknstick's Avatar
I have tried to do the above
I had the ignitiom on
I switched the engine off without touching break whilst holding the lamp switch in
held the light smitch in then turned the engine on
held in the stalk and lamp switch together for ten seconds
but all that happened was that the trip computer reset all fuel consuption averages
so what am I doing wrong
St.Regis
Oct 4, 2024 12:07 PM
JarodL
Mar 7, 2024 01:39 AM
trosty
26
Dec 18, 2022 06:40 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
ayavner
Sep 13, 2015 01:12 PM
