XF swaybar upgrade
Old May 23, 2017 | 04:29 AM
  #61
klfong's Avatar
Originally Posted by XJ8JR
So the ride comfort hasn't changed with the new bar in conjunction with the coilvers?
Nope, just less body roll. Just put in the rear one as well last week. It's effects are not so marked as compared to when I first put in the front ARB but the car is nicely balanced now and drives so much better than when I first did the coil spring conversion for my car. No regrets in doing this mod.
Old Jan 3, 2019 | 10:11 AM
  #62
XJ8JR's Avatar
Sorry to dig up an old thread, but does anybody have any idea if this will also fit an X351 XJ?
Old Nov 24, 2021 | 05:05 PM
  #63
Reaxions's Avatar
Originally Posted by cby210
as I attach photo above, all XF turbo & supercharged use same sway bar
stock one thickness : front : 31mm ... rear 16mm
new one thickness : front : 32mm ... rear 20mm
# stock one front is like a pipe .. new one front is like a mass
therefore, the difference is just 1mm but strenth is very different..
I know this is an old thread, but I was looking for the XFR front sway bar size to order the PowerFlex bushings, as PowerFlex confusingly sells them in 31.5mm and 32.5mm sizes for the XFR. The PowerFlex 31.5mm product page (PFF27-604-31.5BLK) says, "Check size to confirm before ordering," while the 32.5mm PowerFlex product page (PFF27-604-32.5BLK) references a corresponding OEM part number of "XR19697," which I couldn't find anywhere. Luckily, instead of trusting the incorrect information contained in the post to which I'm replying, I measured my own 2011 XFR front sway bar, and wanted to let everyone know that it is not 31mm, but is actually 32mm+. I took multiple measurements along the length of the sway bar and the measurements ranged from 32.33mm on the low side to 32.47mm on the high side. I suspect the slight variance might be due to the angle at which I'm holding the calipers because of such tight clearance (and possibly varying thickness of the bar?).
Anyway, I guess I'll order the PowerFlex bushings in 32.5mm, unless anyone else has experience with the PowerFlex bushings and can confirm the correct size (31.5mm vs. 32.5mm). Thanks.
2011 XFR Front Sway Bar - 32.33mm
2011 XFR Front Sway Bar -32.47mm
Old Nov 24, 2021 | 08:23 PM
  #64
Oxidizer2k's Avatar
awesome. Thanks for the info!
Old Dec 7, 2021 | 04:11 PM
  #65
jahummer's Avatar
Originally Posted by Cambo
Thanks very much! I only need a front bar (have already changed the rear bar to an XKR-S one) so I will contact J.Craft to see if they can do something for the front only.
What?!?! You guys are kidding right??
$550 delivered for a PAIR of sway bars AND the required bushes, for an obscure make/model with very limited aftermarket support.
That's a good price IMHO. You should be happy that these even exist!
BTW the OEM XFR-S front, XKR-S rear and bushes ex-UK;
XFR-S Front Bar $221
Front Bushes $30 x2
XKR-S Rear Bar $247
Rear Bushes $12 x2
Total: $552 + shipping!
The J.Craft bars are cheaper than OEM.
Just fitted these front and rear, can't wait to compare to stock. Won't be for a few weeks more though.
Old Jan 10, 2024 | 04:26 PM
  #66
Hanh's Avatar
How is the improvement compared to stock?
how long to install front and rear by qualified tech? I have the same ARB but have not installed yet. Any tips would be appreciated.
Old Jul 7, 2025 | 09:20 AM
  #67
Brekyrself's Avatar
Anymore feedback on these? About to buy a pair.
Jay_Davis
XF (X260)
Sep 18, 2016 08:33 PM
webshark
Apr 20, 2016 05:44 PM
icebear
Dec 11, 2013 01:58 PM
Randy
Jun 8, 2008 10:02 AM
