XFR 100 Edition - Reg SD11CWN
Old Sep 19, 2020 | 05:41 AM
Chaz's Avatar
Default XFR 100 Edition - Reg SD11CWN
Hi,
I used to own a XF 3.0D (2009 model) some years ago and registered then. So many moons later an I am considering a XFR 100 edition with the reg of SD11CWN (UK). It's a high miles car but has FSH and immaculate condition. It also has some upgrades such as Spires pipe, Pulley and ECU flash.
Is this car known to anyone here? Anything to consider with these? The price is good (I think) for what it is, loved the short test drive earlier today. Just need to pull the trigger (or not).
Old Sep 19, 2020 | 07:53 AM
User 42324's Avatar
Originally Posted by Chaz
Hi,
That's a UK reg & you've posted on a mainly US based site. For info from the previous owner of that specific car try posting it on the mainly UK based site.
www.jaguarforum.com
Old Sep 19, 2020 | 08:19 AM
Chaz's Avatar
Thanks, noted after and have posted elsewhere too. Suppose the question about the model of car remains of interest if there is any experience.
Old Sep 19, 2020 | 11:32 AM
User 42324's Avatar
Absolutely. There are some very knowledgeable & experienced people on this forum.
Old Sep 19, 2020 | 07:35 PM
BritCars's Avatar
To translate to US spec that's a 2011 XFR model? Lots of owners on here. Mine is the 2010 XF SC which is basically the same 5.0 V8 SC
Had it 8 yes now. Been terrific
Would have a very thorough independent inspection done.
Check all cooling system to ensure no leaks - quite a lot of plastic (as with many cars). Timing chain guides can get worn at high mileage on these earlier ones and a pretty expensive repair (and would do lots of damage if left alone). Any ratting sounds?
SC snout can also get worn - listen for clunk on shutdown
How high are miles? I would be ok with decent miles but if v high I would be cautious. Eg my 2010 is 64k miles and you can find plenty of modest mileage ones
Also check all wheels are true - the 20inch allows bend v easily
Old Sep 21, 2020 | 02:02 AM
Chaz's Avatar
This one has 146K, so ye, mostly motorway one would assume (100K in the first 4 years of its life). So ye, risky. That said, you would think that a lot of stuff would have failed and have been replaced at this stage?
Old Sep 23, 2020 | 08:15 PM
BritCars's Avatar
I wouldn't bank on stuff having failed and been replaced. If it's 150k miles mostly highway then I doubt timing chain or SC is done yet. You can perhaps pull service records. Cooling system is more about heat cycles than miles
So it could be fine. But if it were me I'd look for a much lower mileage one or a few yrs newer if I could find it. But stick with the V8 SC engine!!
Old Sep 24, 2020 | 03:35 AM
Chaz's Avatar
Thanks, appreciated.
I have looked through all the invoices and receipts, there's the usual stuff, waterpump / condenser failure but nothing regarding the timing chain / tensioners. They are asking the previous owner but it looks like it may not have been done as yet. I do need a car soon but not in a position till early next year to look at something more expensive. Ill keep a watching brief on ebay and other sites for new cars - I agree, I do like what I drove and certainly something I'd like to get in future.
Injekter
Aug 20, 2015 01:30 PM
tomrisky
Feb 9, 2013 05:07 PM
dsmith
Oct 8, 2012 09:23 PM
RoswellJAG
Sep 25, 2012 08:26 PM
davidcalgary
Jun 22, 2011 08:45 AM
