XFR Changing Shifter - Need to Program?
Old May 10, 2025 | 05:00 PM
njhosta's Avatar
Default XFR Changing Shifter - Need to Program?
Hi,
I have a 2014 XFR and the shifter is starting to stick, usually in reverse. I picked up a used shifter to swap in and I'm wondering if it needs some kind of programming.
I think the problem is with that solenoid activated lever that locks the shifter when power is off. If it is does anybody know a way to fix that?
Thanks, Bill
Old Jun 16, 2025 | 11:38 AM
gretle_2.0's Avatar
Originally Posted by njhosta
Hi,
Thanks, Bill
you can actually solder the one joint that cracked. I had this issue over last summer and just added some more solder to it and it was fine.
Latvad
Dec 25, 2022 02:29 PM
losfinch
Jan 7, 2022 10:30 PM
BigCat09
F-Pace (X761) / C-X17
Dec 30, 2016 12:24 PM
XJ40ish
XJ40 ( XJ81 )
Jun 15, 2007 10:56 AM
