2009 XFS 3.0D DPF replacement
Old Jun 15, 2025 | 03:30 PM
JoesGrandad's Avatar
Default 2009 XFS 3.0D DPF replacement
Hi all,my grandsons XF has been having restricted performance issues.
A friend scanned it with a Solus pro and it gave the folliowing codes
P006a map sensor low pressure
P244b dpf prrssure to high bank 1.
Looking under the car revealed a snapped cable to egt sensor 3,uopn trying to rrplace said sensor it snapped (obviously) so hes just bought a second hand dpf from a 50k mile car which Im going to swap at the weekend but my question is ,does the newer dpf need to be coded or anything or will it just rrad the pressurr etc on its own and sort itself out,thanks.
Old Jun 16, 2025 | 07:13 AM
webb 72's Avatar
recognizes and properly manages the new or replacement DPF.
Here's why:
  • Sensor Calibration:
    A DPF differential pressure sensor, which is part of the DPF system, needs its offset programmed into the ECU after replacement.
  • Proper Regeneration:
    The ECU needs to be aware of the new or replacement DPF to initiate and manage the regeneration process correctly. Regeneration is the process of burning off accumulated soot from the DPF.
  • Fault Codes:
    Without proper coding, the car's computer might trigger error messages (fault codes) and potentially reduce performance or even enter a limp mode.
Therefore, after replacing a DPF, it's crucial to have it coded using the appropriate diagnostic tools.
Your going
Old Jun 16, 2025 | 07:20 AM
Thanks for clearing that up.Do you know if would be a case of just telling the car to reset/rrlearn or would you know if measurements have to be taken from the dpf and programmed through the software?
Old Jun 16, 2025 | 01:24 PM
webb 72's Avatar
Get your buddy to scan it, maybe he can reset it
Old Jun 16, 2025 | 01:52 PM
Yes thats what I was thinking,thanks for your help
stevep10
Apr 27, 2025 08:18 AM
barry johnson
Jan 14, 2024 05:32 PM
superv803
Feb 13, 2022 10:21 AM
Enosgl
Jan 3, 2022 07:00 PM
Jakejag
Oct 25, 2021 01:34 PM
