Xfr s/c 5.0 engines that are blowing
Old Nov 25, 2017 | 10:41 AM
  #101
mghirsch's Avatar
Originally Posted by jagular
Modern engines burn very little oil unless they develop a serious fault.
Not true. Honda nd Toyota, for example, have had serious oil burning problems.
I understand that Audi may have similar issues.
It all boils down to the manufacturers using low compression piston rings to increase mileage.
Old Nov 25, 2017 | 11:30 AM
  #102
clubairth1's Avatar
Community Influencer
Yes I would use a length of braided SS hose to place the gauge where it would be out of the way and much easier to read.
Of course it's another possible leak point too.
Old Nov 26, 2017 | 01:34 PM
  #103
Polyesterpig's Avatar
Wouldn’t it be simpler if your Jaguar flashed your oil level for a few seconds whenever you started your car on level ground? My 2011 XJ has 91,000 miles on it and I do the oil changes. Around 60,000 miles I changed the oil and made sure it was at the full mark. No surprise since I put in 8.75 liters of Jaguar oil with a filter. A week later I checked the oil level and it was down 3 liters? I checked it again a few times to confirm it wasn’t a bad sensor. I put one liter in at a time and waited until it read full. It took 3. If I would have had someone else do the oil change, I would have blamed them for under filling the oil. I ended up cleaning the manifold and the crankcase valve ( pretty clogged up) The issue never happened again 30,000 miles later. I have no idea where that oil went? I pulled the bottom pans and the only leak was the rear main seal , which I had replaced at 80,000 miles.
Old Nov 27, 2017 | 08:38 AM
  #104
clubairth1's Avatar
Since you do your own oil changes what oil did you use?
Drain plug or use a vacuum remover?
I just found out how to check the oil and I have had the car 2 months already!
Old Nov 27, 2017 | 10:17 AM
  #105
Drain plug or use a vacuum remover?i
I do the vacuum method. I purchase the oil from my local Jaguar dealer @ $8.75 liter, but I buy my oil filters online via Reno Jaguar. The local independent Jaguar service center uses Motul oil.
Old Nov 27, 2017 | 10:27 AM
  #106
Etypephil's Avatar
Originally Posted by Queen and Country
One thing that I do know for a Fact-
Jaguar's oil computer will not let you take a erroneous measurement, such as not waiting till all the oil is drained back in the pan or while the oil is cold.
That is partly correct; the system will not give any reading until the oil has fully drained back, but does work on a stone cold engine, giving a reading around 3/4 along the bar & showing OIL LEVEL OK, when doing it according to the instructions would show the whole bar; presumably because the oil expands when it's warm, giving a higher reading.
Old Nov 27, 2017 | 10:49 AM
  #107
Queen and Country's Avatar
I have little faith in your ability to rationalize.
I saw your suggestion in another thread that we should go around shooting cats. Why do you buy cars that have cat insignia all over them?
Old Nov 27, 2017 | 09:43 PM
  #108
Etypephil's Avatar
And I, in yours; nom de plume, for example. Country is fine, but queen? Is that queen as in chief parasite, or queen as in Freddie Mercury?
The rationalisation is simple enough:-
Jaguar the car; the best value available, new or used, and in all important respects superior to any other manufacturer's product. It does what I want perfectly.
Jaguar the animal; quite different from the scummy creatures kept by some sub humans in order to annoy their neighbours.
For the record; I did not suggest that we should "go around shooting cats", but that shooting trespassing cats in the back of the head would prevent them from further damaging one's property; not the same.
Old May 8, 2022 | 02:56 PM
  #109
shrinktfit's Avatar
I had the same problem with a Lotus Super 7! It ran a modified Ford Cortina engine and I spun a rod bearing racing a Porshe on a slolom course. The engine was oil-starved, but only on hard turns in one direction. The solution was to go dry sump or install baffles. I did neither, just stopped racing it.😢
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
Corycarlo
Sep 5, 2015 11:41 AM
edtexas
Sep 5, 2015 10:49 AM
lazeebc
Sep 5, 2015 02:34 AM
OkieTim
Sep 2, 2015 12:48 PM
