XFR S/C belt wear - shedding rubber in bay - help needed
Old Oct 11, 2021 | 05:42 PM
VicVegas84's Avatar
Default XFR S/C belt wear - shedding rubber in bay - help needed
I finally got the car back together. I noticed this wear in the engine bay on my Mira pipe and down by the tensioner. Has anyone seen this before? It accompanied an odd chugging / lower idle. My greatest fear is this is a result resistance and the supercharger binding up as I experienced some tolerance issues with the coupler.
Note that I may have reversed the belt from it's original rotation on installation but I'm not certain.
Old Oct 18, 2021 | 02:03 PM
mlrtime99's Avatar
That looks more like someone cleaned your engine bay and used a rubber protectant/armor all/black magic something like that and you're flinging those oils. I see the same thing on the body of my car after they 'slick' my tires up.
Old Oct 19, 2021 | 07:26 AM
VicVegas84's Avatar
I had just put the car back together (SC/cooling system service) and didn't use any clearers. I'll probably replace the belt in spring for peace of mind.
Old Oct 19, 2021 | 05:35 PM
Oxidizer2k's Avatar
Is the tensioner still tight?
what kind of issues with the coupler? Did you end up with a factory coupler?
Old Oct 23, 2021 | 10:55 AM
VicVegas84's Avatar
I believe this is wear in as I reversed the belt. I'll replace it in spring.
I briefly had the ZZP coupler on my car (2011, vacuum operated) and to get it on the charger I regrettably used a rubber mallet to seat the snout and charger with the clearances on the coupler being too tight. I replaced the coupler with a factory after much deliberation. there was some movement on the snout as it was binding up the bearings on the charger. This has been resolved.
I've had no further issues.
krock205
May 5, 2019 07:27 PM
krock205
Mar 27, 2019 09:43 PM
capitaineInsano
Jul 27, 2018 07:38 PM
tsuppari
Feb 28, 2017 02:29 PM
larueb
Apr 19, 2014 09:50 AM
