how is this, its proof but and will look better with the brushed chrome background. The printing method I use wont allow some of the detail that the original has so I used a substitute growler. I can keep trying but would probably need a sample here so you'd have to send one along. Let me know
I like the way it turned out - I put some work into the car - fully serviced and a brand new leather Jaguar dash installed - THANK YOU Carlos Ponce at Galpin Jaguar for simply excellent service (as always).
I had all of the dark gray wood trim refinished - a big shout out and THANK YOU to Madera Concepts for their excellent work, as well as Chris at MINA GALLERY for the carbon fiber front splitter.
Last but not least, THANK YOU Jssaab for the amazing Jaguar center
caps that he designed for the TSW wheels - they look fantastic!
In addition to the upgrades (the car also has a MINA GALLERY axle back exhaust), I replaced all of the switchgear in the interior with new switchgear. Interior looks brand new!
What is the offset on the rear wheels? I am looking for a set of wheels for my XF 5.0 Supercharged. I am just so sick of bending my wheels all the time to the point where the car isnt driving smooth anymore and need something to replace them. Ideally I want to get a set of wheels that would fit this and the XJ Supercharged as I would intend to replace my XF with that once im done with it. Curious what the Farallon rear wheel offset is with him rubbing. I am at stock height so hopefully I wouldn't experience rubbing with that aggressive of an offset and 305s or 295s
The XF 5.0 SC and XFR have the same offset on the rear. So if they work on the XFR they will be good on the 5.0 SC too
The other XF models have quite a different rear offset
I know that, I need to know what the limit is for rear offset cause as seen in the original photos and described he seems to be rubbing but FastCat seems to have an aggressive offset as well. Want to get this sorted ASAP because I cannot drive my car as is...
XFR wheels were an option on my 3.0 AWD.
I bought a set from a member here with and XFR and am running them now, no issues. Love them, transformed the handling
Are you running spacers? The rear wheels are an inch wider than the stock ones (9.5 vs 8.5) but because of the different hubs on the 3.0 AWD by my calcs all of that inch will be on the inside of the car. the outer edge of the wheel will actually be recessed a little further into the car. So some spacers might be a good look
I didn't see much around about fitting the wider XJR wheels from a 2013 -2014 car onto my x250. I recently did this for the looks, wider tire, and lighter wheels. The stock XJR Farallon wheel is forged and possibly 10lbs (ish?) lighter than my xfr wheels.
They fill the fender much better, and everything fit without any rubbing issues. The XJR wheels are wider and the rear tires went up to 295/30 so i was worried about that. On a side note the newer XJR tpms worked as well. All around I am happy with the upgrade. Stock XFR left, new XJR right
These are the GLOSS BLACK and they have the correct TPMS already mounted as they were on my old 2012 XJL Supercharged 5.0
I would prefer pickup
XJR Farallon Gloss Black set with Michelin PS4 50% life left
265/35ZR20
295/30ZR20
Don't know what the offset is on the Farallon Wheels - I know my news wheels are 45 mm offset at the rears, 21"x 10.5' size - fronts are 21" x 9", 40 mm offset.
