xk rims on xf?
Old Aug 11, 2015 | 12:04 AM
crackersntea's Avatar
Default xk rims on xf?
i have a 2010 jaguar xf prem lux 5.0. I saw a local ad on craigslist for some 19"xk wheels that came off of a 2010 JAGUAR XK coupe .
ad listing:
"2010 JAGUAR XK 19" WHEELS & TIRES 5X108"
"THIS SET OF RIMS IS OFF A 10 JAGUAR XK COUPE. THEY ARE 19 INCH 5 LUG STAGGERED WHEELS WITH SUMITOMO TIRES."
wanted to know if these would fit on my xf???
Old Aug 11, 2015 | 05:46 AM
Bigg Will's Avatar
ad listing:
They will bolt on, but you need to check for clearance issues.
Old Aug 11, 2015 | 06:54 AM
damienedwards's Avatar
http://s3.photobucket.com/user/JTDamo/media/20150517_1432271.jpg.html?sort=3&o=4i buddy,
i have XKRS wheels on my XFR and they fit perfectly.........quite a bit more offset poke but IMO look better for it.
Old Aug 11, 2015 | 10:43 PM
BritCars's Avatar
Ask for the offset numbers (they will be stamped inside the wheels ET and then some number of mm of clearance. E.g. on my XF SC they are 49mm front and 66mm rear. You can then compare to your existing wheels (you will be 49mm front, not sure about your rear) and decide if the difference matters. My guess is that on a non-staggered setup the difference isn't too great and you will prob be ok with them. However I found on the staggered setup (wider wheels at the back) the XK staggered wheels ended up being too far off on the offset. Part of that's a matter of taste of course, but you would need to be sure that they clear the wheels ok too
Hope that helps
Old Aug 12, 2015 | 06:16 PM
jaguny's Avatar
Can't recall when but XK rear offsets were in the high 20's, but then changed, possibly in 2010 to somethinget with higher number. As said you need to check.
robbing
Mar 5, 2024 10:51 AM
Larry-Cleveland
Feb 9, 2019 03:17 PM
Marque
Oct 11, 2015 05:59 PM
Marque
Sep 27, 2015 10:28 PM
