Zip tie method
Old Apr 5, 2019 | 07:29 PM
garysaunders85's Avatar
Default Zip tie method
Is there a zip tie method on changing the timing components? I have a little chain rattle that goes away when it's warm and heard there is an easy way to change the guides and tensioners? 2010 XF 5.0
Old Apr 5, 2019 | 07:38 PM
mrNewt's Avatar
Well... not sure how to put this without being shut down...
There are ways to lock your cams in place without a timing kit... and some do use zip ties... but I would strongly recommend against it. Is very easy to screw things if you don't use proper tools.
I would strongly recommend you to buy the timing tools... there are very cheap and easy to be found on eBay. Investing $100 - $200 on tools is cheaper than rebuilding/replacing an engine.
Old Apr 5, 2019 | 07:42 PM
My independent may have the tools. How hard is it to change the guides and tensioners? How long does it normally take?
Old Apr 5, 2019 | 07:50 PM
mrNewt's Avatar
Have you ever done anything similar?
I'm am actually in plan to start doing mines at the end of this month.
I've done timing chains before on Honda cars, 4 cylinder cars. Fairly easy and is about half a day to a full day of work.
From my readings, for the V8 on this car will be slightly more complicated. I will be giving myself some time on it and do things slowly and properly (I have a few other things lined up). Probably it will take me around 2 weeks to finish everything I have planned.
A competent mechanic should be able to do the swap in maximum 2 days.
Old Apr 5, 2019 | 07:51 PM
if I could find a write up in detail on what needs to be done it's possible. I do basic stuff on vehicles and this may be over my expertise. But I do know some people that could.
Old Apr 5, 2019 | 07:54 PM
mrNewt's Avatar
Check my thread - a LOT of great guys helped me out with all the manuals I could possibly want.
Go there and start downloading...
Timing chains and others
Old Apr 5, 2019 | 09:20 PM
I definitely appreciate it. It looks like it’s over my head. Now I just got a find somebody that wants to attempt it
Old Apr 12, 2019 | 05:57 PM
xfportfolio's Avatar
Yes, there is, and looks like it is an official method. Davetibbs posted it in this thread : timing chain tensioner engine set (.pdf file).
byjosh
Apr 2, 2016 08:56 PM
sbreeden
Dec 30, 2014 02:46 PM
daboss085
Nov 1, 2012 05:13 PM
coastaljag98
Sep 26, 2012 05:50 PM
SkinnyLard
Aug 9, 2012 11:07 AM
