A good test of the Harmonic Balancer
Old Nov 11, 2012 | 05:54 PM
EZDriver's Avatar
Smile A good test of the Harmonic Balancer
I was pretty convinced my main crank pully, better known as the Harmonic balancer, was beginning to fail. So I talked to Motorcarman about getting it replaced. The logistics was going to be a nightmare. My local Indy was not so convinced. One thing that Bob Gauff recommended I do was to test the damper (thanks Bob for the idea). The test was to mark the timing wheel and each of the pulley flanges with a dob of white paint or white-out. Then keep an eye on it and if it is failing the marks will move in relation with each other and will no longer be aligned. Well I did that. And so far they are still aligned.
My Indy which is a great guy and a good thinker looked under the hood and he thinks the occasional squeal was caused by a very slight drip from the water pump. You could see evidence of coolant being slung from the belts, although very slight. Looks like a new water pump is in the future.
I know that even a few drops of coolant can cause a belt squeal.
Any one have a thought the damper pully is becoming delaminated should do the white-out check recommended by Motorcarman, Bob Gauff.
Thanks Bob. But sorry that I probably won't be bringing the car over. At least not for that problem.
dsnyder586
Dec 29, 2024 07:39 PM
Wolfy
May 28, 2024 08:06 AM
way2far
Aug 31, 2022 09:26 AM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
XJsc-guy
Sep 2, 2015 11:43 AM
