Locked my only key inside the trunk
You will have to order a new one from the dealer to unlock the door but then, you will have to get all your keys re-programmed. I did the same thing awhile ago, this is the course of action I had to take.
Read my recent post
Loot in the Boot
I recently had an issue entering my boot while away got an automotive locksmith out he picked my seized lock.
15mins and £20 cash and he was in....
Good luck !!!
Loot in the Boot
Good luck !!!
Worked perfect!! Thanks
Guest
Posts: n/a
I think you should consult a good car locksmith. They consign always arrive in utterly equipped vehicles, ready to get together allotment demand further fulfill the job done right, prime time, whereever you are. You can rest easy, knowing that each of our locksmith technicians have been carefully pre-screened and selected to make sure that your technician is not only skilled, but trusted and able to complete any automotive locksmith lust you have useful in that.
I'm glad that you guys have got your keys back again but I'm slightly puzzled. How the heck did you manage to lock your keys in the trunk in the first place? Was it a case of .....
I must take this suitcase out of the trunk.
I'll use the key to open the trunk and keep the key in my hand.
Ooops, I need 2 hands to lift out the suitcase but what shall I do with the key? Shall I put it in my pocket or shall I just drop it next to the battery?
I'll put it in the trunk. What could possibly go wrong.
Is that how it works?
It is always a good idea to keep a local locksmiths number programmed into your phone. You never plan on needing a locksmith but it sure is nice to have them when you do!
<a href="http://a1autounlock.com">http://a1autounlock.com</a>
The key of my X300 1995 has a chip and is programmed. This is what prevented some thieves to take it with them.
The key for my '96 X300 is programmed also, as I had to have this done by a main dealer when organising a spare. The OP is based in the U.S. and they don't have the same immobiliser/alarm set up as European cars, so maybe that's relevant?
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
Nov 23, 2015 01:56 PM
