99 XJR can't get out of park
Old Oct 24, 2013 | 12:29 AM
nronald1's Avatar
Default 99 XJR can't get out of park
Hi, I am new on here but have used these forums before and found them to be super helpful. I know there have been at least one previous thread on an XJR that won't shift out of park. I found that when this problem occurred in my vehicle I was thinking brake switch as well but also had no map lights, no power to steering wheel, exterior mirrors, and I am wondering if this is more electrical, ie; fuse or wiring related, before I swap out the brake switch. Any thoughts would helpful.
Thank you
Old Oct 24, 2013 | 02:50 AM
Welcome to the forum nronald1,
To get over the immediate issue of not being able to shift out of Park, use the Manual Override procedure (see section boxed in red):
Although it could be a failed Interlock Solenoid causing this specific issue, the fault list suggests there's more to it.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Oct 24, 2013 | 11:11 AM
nronald1's Avatar
Default Thanks
Thank you, and I took care of the new member intro as requested. I am about to see if I can fix her.
Old Oct 24, 2013 | 11:42 AM
nronald1's Avatar
Default Fuse
GGG,
Thanks again for the info. Just passing along some info that it was the #7 fuse (Left heelboard), 15 amp which controls multiple functions such as processors and relays thus knocking out so many functions. In the event anyone has any similar problems in the future and I miss it. Thank you again for the heads up on other potential problem areas.
Ron
Old Dec 30, 2013 | 05:54 AM
t.rhodes64's Avatar
Default 1993 XJ40 gearshift interlock
I have the same issue....I went thru all the fuses after i found this problem where I cannot shift out of park and still cannot get the car to come out of park without inserting a pin in the interlock over ride...i found multiple fuses blown and replaced them, problem still exist....anymore guidance here?
Old Dec 30, 2013 | 06:19 AM
Ericbilt25's Avatar
Do the rear brake lights work? It could be a bad brake light switch? I experienced this a lot on Ford vehicles, but not sure about Jaguars they're fairly new to me.
Old Jan 1, 2014 | 04:30 AM
t.rhodes64's Avatar
im in the process of replacing the alternator...it's sucking voltage from the NEW battery.
Old Jan 1, 2014 | 09:13 AM
rvaha's Avatar
I had this same problem. Make sure your brake lights work. I had a broken wire on the brake switch. A bad brake switch will do the same thing.
St.Regis
Oct 4, 2024 12:07 PM
Rlover
Mar 30, 2016 10:04 PM
adam699
Sep 12, 2015 05:32 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
