XJ ( X351 ) 2009 - 2019
2010 x351 3.0d oil change
Old Mar 10, 2025 | 04:20 AM
  #41
KiwiJon's Avatar
Originally Posted by Pacer
What is the purpose of vacuum driven axle that sits just on the port out from EGR cooler, where the recirculated gas exits and goes into intake? ECU driven motor in EGR valve vs. vacuum driven valve on EGR cooler outlet?
I don't know but hope so. The car is tuned before my ownership by a Finnish guy that has been playing with these cars. It might be though interesting to drop the oil pan and see the pick up and replace it. Can't remember now was it easy to drop or behind front frame or something...
The Oil sump pan on the 3.0D is a cow to remove - really is best to drop the subframe first (I did this the second time I had to drop the sump pan. Otherwise you are required to undo 2 bolts INSIDE the oil pan through a very small gap. That is not a nice job at all.
Old Mar 10, 2025 | 10:52 AM
  #42
Vasara's Avatar
Thanks! I've got one that has 3448 pages, maybe the same if you were not quite exact with that 8000 pages?
​​​​​​​Same guy.
Ohh.. Sorry: 3448 pages are correct
You are good. He knows how EGR delete shall be done.
sanchez
Jan 12, 2025 04:30 PM
jindra
Feb 23, 2023 12:08 PM
MWags
Aug 20, 2017 10:27 AM
shoeboy
XJ40 ( XJ81 )
Jan 29, 2012 03:17 AM
JagScott
Dec 12, 2011 09:03 PM
