XJ ( X351 ) 2009 - 2019
2011 Xj Fan not working x351
Old Mar 8, 2020 | 08:40 PM
Unclereggie's Avatar
Default 2011 Xj Fan not working x351
Hey guys I just noticed today my xj started overheating at idle , all leaks were repaired bone dry , it only climbs at idle. no matter what I pressed to normally kick on the fan it did not kick on at all , should I just replace the unit or could there be another issue with the fan ? Electrical maybe I’m not sure which fuse controls the fan /relay ... any help please !
Old Mar 9, 2020 | 07:19 PM
XJ8JR's Avatar
I had a similar issue but on my old X350 XJ. I ended up just replacing the fan with a used unit.
Old Mar 11, 2020 | 11:11 PM
Darealwoody's Avatar
Open the fuse box under your hood. You will then see a silver thin metal tab which is the tab that is used to jump start your car. That tab is also attached to a 100amp MIDI LittleFuse Fuse. Copy and paste it and that is what you’ll need. All you’ll have to do is just get a small little socket I can’t remember the size but I’m thinking a 8mm and remove the 2 nuts and take off the little tab, then use a lil meddle nose pliers to remove the little fuse. That fuse is your fan fuse. It happened to me twice tryna jump start someone. So I just purchased a few of them for keeps.
Old Mar 12, 2020 | 04:58 AM
thierry_1500's Avatar
I always considered that tiny tab was mostly for loading the battery or powering the electronic including trunk lock when battery was dead... for jump starting I would be quite reluctant to use it...The fact you say the fuse blows seems to confirm...
Old Mar 13, 2020 | 09:47 PM
Hey guys thanks for the help , after a little more digging I found the fan was simply unplugged ! It’s all fine now .
Old Mar 28, 2020 | 07:05 PM
Polyesterpig's Avatar
A quick test is start the engine and turn on the a/c. The fans should kick on. If not your fan isn’t working. Glad you figured it out.
Mikesxf
Jul 18, 2024 06:36 PM
Ceckman
Jul 27, 2021 01:05 PM
jvickers
Jul 1, 2019 12:46 PM
snepo
Jul 21, 2018 09:29 AM
Polyesterpig
Aug 30, 2017 04:01 PM
