XJ ( X351 ) 2009 - 2019
2011 XJL - Rear Sun Screen
Old Dec 15, 2018 | 03:21 PM
stremsjg's Avatar
Default 2011 XJL - Rear Sun Screen
My rear sun screen does not work on my newly purchased 2011 XJL with 39k miles. I hear nothing when I press the button. I can lift the screen partially but that did not do anything. Can someone tell me where to look for the fuse as I want to check the fuse out. I noticed when I took delivery of the car, the battery had been changed with a sticker of 11/17, so I assume the battery has been replaced. Any help with my problem would be appreciated.
John
Old Dec 17, 2018 | 06:46 AM
dmchao's Avatar
Theres a fusebox under the hood, on the right hand side. There's also one in the trunk/boot on the right hand side covered by a small removable panel.
Old Dec 17, 2018 | 07:15 AM
XJsss's Avatar
According to the owners manual sunblind is fuse F21 a green 30 amp in the trunk fuse box. If you do not have the owners manual it can be downloaded from the forum.
Old Dec 17, 2018 | 07:28 PM
stremsjg's Avatar
Thank you for locating the fuse. I will check to se if the fuse is blown.
Old Dec 18, 2018 | 03:59 PM
Geoffrey Fake's Avatar
the fuse is behind the armrest from the rear Seat, pull the armrest down, and move up the carpet in the hole and you will see a big box with all fuses for interior staff.
Terrific
Mar 23, 2020 02:01 PM
Chuck Schexnayder
Aug 27, 2018 11:50 PM
anilrana1961
Apr 16, 2018 10:48 AM
Shaemus
XJ40 ( XJ81 )
Oct 17, 2013 10:46 AM
Scott Bourne
Mar 31, 2012 12:24 PM
